Axle shaft removal
Old Jul 23, 2012 | 06:45 PM
97z28k&N's Avatar
Axle shaft removal
What is the yellow spring like structure in the center? I haven't seen it before and i'm not quite sure what to do with it. Could someone list the complete steps for removing the axles from where i currently am in the process?
Thanks.
Old Jul 23, 2012 | 07:33 PM
Dave89IROC's Avatar
That's the springs for your posi
Old Jul 23, 2012 | 08:49 PM
97z28k&N's Avatar
Re: Axle shaft removal
I have never read of these springs being in the way. What do i have to do in order to access the c-clips? I would like to finish this tomorrow and i really need to know how to get to the c-clips.
Old Jul 24, 2012 | 08:35 AM
Remove this shaft and you will be able to access the c-clips through the openings in the differential case. You will have to push the axles inward to release the clips. I use a telescoping magnet to keep the clips from going anywhere.
Old Jul 24, 2012 | 01:45 PM
97z28k&N's Avatar
well I replaced the bearings and seals just to find out that the old ones were fine. The problem is the pinion bearing, which the shop failed to tell me. they said "bearings in rear are shot". what can I even do know? they want $800-$1300.
Posted from Camaroz28.com App for Android
Old Jul 25, 2012 | 11:11 AM
That's ridiculous. A gear install kit with new bearings is $100. A complete gear install labor is $350 max. Should be a little less for just the bearings.
Old Jul 25, 2012 | 10:11 PM
97z28k&N's Avatar
I agree with it being ridiculous. They told me that "the rear must be completely disassembled to access the pinion bearing and then after that the gears must be reinstalled.
Old Jul 25, 2012 | 10:18 PM
97z28k&N's Avatar
I really don't know the process, but at $50-$100 an hour, I feel like they'd be taking wayyyy too much time .... carefree if you ask me.
Old Jul 25, 2012 | 10:30 PM
That is true.
Old Jul 25, 2012 | 10:49 PM
You would pull the bearing caps, and lift out the carrier with the ring gear still assembled, then have access to the pinion for bearing replacement.
Old Jul 26, 2012 | 09:32 AM
97z28k&N's Avatar
so what should I look for as for a reasonable price? I would say I'd take on this project myself but the differential makes me nervous. Replacing the wheel bearings has me beat!
Old Jul 26, 2012 | 09:57 AM
97z28k&N's Avatar
well I have better news. I called a shop called "M & H Transmission" that claims to rebuild differentials. Over the phone, they told me that "we cannot just replace the pinion bearing, we must do all of the bearings and seals. The total would be between $500 and $600". I like that a lot better than $800-$1300 for ONLY the pinion bearing.
Old Jul 26, 2012 | 04:11 PM
I didn't suggest that you replace ONLY the pinion bearing. I was simply explaining how easy it is to access the pinion bearing. A good install kit, as I already suggested, includes the pinion bearings and the carrier bearings. Once you have the carrier out you press the end bearings off the carrier, press the new bearings on.
Old Jul 26, 2012 | 08:39 PM
97z28k&N's Avatar
oh i know you weren't suggesting that, I was just telling you that the shop quoted me for only the pinion bearing, nothing else.
Victor Lamb
Aug 26, 2017 02:52 PM
Apr 16, 2015 09:57 AM
KYWes
Apr 15, 2015 07:28 PM
4586
Jan 3, 2015 07:22 PM
cmdeshon
Dec 27, 2014 10:06 AM
