Should I use washers on my differential ring gear bolts?
Old Jan 7, 2012 | 01:11 AM
SSinister11x's Avatar
My 96 SS is getting a new carrier and ring and pinion. I lost my original ring gear bolts. My new diff is an Eaton model without a reluctor ring. Im going to be ditching the ABS in the car anyway. Anyhow, I was wondering the best place to get new ring gear bolts and does this Eaton posi need washers on the bolts? Thanx for the replys
Old Jan 7, 2012 | 07:00 AM
FirstYrLS1Z's Avatar
Re: Should I use washers on my differential ring gear bolts?
Ratech 1303 - Ratech Ring Gear Bolts - Overview - SummitRacing.com
no washers,a washer can allow a 'loosening' effect.
FYI,the bolts are 'left hand' thread.
Old Jan 7, 2012 | 07:06 AM
96capricemgr's Avatar
Not specifically on topic but consider getting a Ratech "smart sleeve" for the crush sleeve, they are a lot easier to set up and are supposed to be stronger.
On the bolts as said they are a left hand thread without washers, they also need a dab of thread locker.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Feb 1, 2015 08:26 AM
TitoPR221
Jan 29, 2015 08:00 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
