4l60e vs 700r4
Old Dec 20, 2011 | 03:44 PM
z28er_kgb's Avatar
4l60e vs 700r4
Witch one is better for the lt1? Pro's and cons?
Old Dec 20, 2011 | 03:47 PM
ray396's Avatar
Re: 4l60e vs 700r4
Hi, My 2-cents. I like the 4L60E. better response, adjustability
Old Dec 20, 2011 | 03:58 PM
Re: 4l60e vs 700r4
Since it looks like you have a 94, you will want the E model, as your PCM is made to control it. The TV cable on the 4L60 can be finicky to get adjusted correctly.
Old Dec 20, 2011 | 04:00 PM
96capricemgr's Avatar
Re: 4l60e vs 700r4
A properly rebuilt 700R4 will include parts from the updated 4L60E.
They are essentially the same transmission except for the electronic valvebody but since the 4L60E was built later it got improvements.
The trick is to actually use a shop that can build them well. Many will claim they can few actually do. Most shops will struggle to keep one alive in a 12 second car, others can keep them alive in a 9 second car.
Some incompetent shops will tell you a manual valvebody 700R4 is the ticket to keep one alive in an 11 second b-body but mine is a nothing fancy 4L60E from pro-built.net that is 8 years old.
The rebuild before this one was a large local tranny shop and it lasted barely a year behind a couple hundred HP less than the car has now.
Old Dec 20, 2011 | 04:49 PM
z28er_kgb's Avatar
Re: 4l60e vs 700r4
Thanks for the info.
Old Dec 22, 2011 | 06:24 PM
12SCNDZ's Avatar
Re: 4l60e vs 700r4
The 700 and the 4L60E can both be built to be equal in strength. Keep in mind that '93 F-Bodies came with 700's (4L60). '94 was the first year for the E. To put a 700 in a '94 you'd have to swap to a '93 style throttle body that has a pivot for the TV cable. You'll also need a TV cable bracket, and obviously a '93 LT1 specific TV cable. You'd also have to figure out your wiring to make the TCC operable in a 700. I usually suggest 700's for people doing 6 speed swaps, but the brackets, and cables are getting hard to get...Even from GM. The nice part about the 4L60E is it's tuneability through the computer. As far as how much abuse they'll take... I can only speak from my experiences. I have a '60E that's been in the 9's for 7 years, in a Procharged and nitroused 3600# '98 Firebird. While that's cool, I'm still a little more impressed in one I've got in a 4200# Impala SS with a fogger that's running 10.20's @ 133 MPH with 1.33 60 ft. times. Cutting those 60 times with 4200#'s is hard on a transmission...LOL Fastest 700 I have is running 10.50's in a LT1 converter Mazda RX7 on spray.
Frank
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
