where can i get a 10 bolt rear spider gear thrust washer
i was taking apart my rear and noticed one of the thrust washers is cracked and i dont want to roll the dice and put it together knowing its cracked, does anybody know where i can get one?
thanks
thanks
Re: where can i get a 10 bolt rear spider gear thrust washer
pitstopusa has em
Ratech 1100
Also they come in the ring/pinion install kits if thats what your doing
Ratech 1100
give me the dimensions
outside diameter
inside diameter
height of the 'bowl'
I save all usable parts from rears,I might have one/some.
I have 2,they measure 1 21/32 OD,25/32 ID,5/32 'bowl height'.
outside diameter
inside diameter
