Where to get flywheel and clutch balanced?
Old Oct 19, 2012 | 06:57 PM
Z28-50's Avatar
As the title says, where is a good place to get a flywheel and clutch balanced?
95 LT1 M6. I am in Shelby Township, MI (Macomb county).
About to pull the trigger on a Mcleod street twin setup.
Mcleod techline recommends balancing. Seems like for the money it should come balanced.
Old Oct 20, 2012 | 01:17 PM
Re: Where to get flywheel and clutch balanced?
Are you neutral balancing the flywheel, for use on an internally balance rotating assembly, or are you attempting to replicate the stock flywheel balance weight setup, for a stock externally (rear) balanced rotating assembly?
Old Oct 21, 2012 | 09:25 AM
Z28-50's Avatar
Replicate the stock flywheel balance.
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Ericksd
Sep 16, 2015 07:08 PM
Daluchman1974
Sep 11, 2015 06:12 AM
