rearend swap
Old Apr 12, 2012 | 01:04 PM
dzltek's Avatar
rearend swap
Just wondering if there are any rearends that will swap into a 4th gen without having to spend 2500 dollars on a moser rear. Thanks for any help.
Old Apr 12, 2012 | 01:21 PM
greenformula94's Avatar
Re: rearend swap
You could spend less if you can fabricated and weld.
Could buy a 8.8 ford rear end, usually 31 splined axles. out of alot of diff cars or trucks. Would have to shorten both sides, and get the axles welded and redrilled for our bolt pattern, and cut all the mounts off and weld all your mounts back on.
its alot of work but could be done.
could also find a 9 bolt rear end out of a 3rd gen, they are stronger then 10 bolts. But if you do that then you will will have to run spacers or modify your inner wheel wells because they have a shorter stance.
Old Apr 12, 2012 | 09:08 PM
dzltek's Avatar
Re: rearend swap
I can do the work, and would rather go that route. I was wondering how close an 8.8 would be, cause I know they go in s-10's really easy. Before I start making some serious power, I want the trans and rear as stout as possible. Thanks for the help.
Old Apr 13, 2012 | 02:17 PM
chevy_dude97's Avatar
Re: rearend swap
summit has 9 inch rears for like 1200 bolt in.
I seen one guy on ebay for less.
I know there is a guy who sells used strange and other aftermarkets pulled from his yard.
Old Apr 23, 2012 | 10:18 PM
dzltek's Avatar
Re: rearend swap
Thanks for the info. I'll be checking summit out.
Old Apr 23, 2012 | 10:21 PM
dzltek's Avatar
Re: rearend swap
And I've been thinking about mini tubbing the car.
Old Apr 23, 2012 | 10:55 PM
Re: rearend swap
Typically, for $1,200 you get the housing and the axles. Double that (or more) with a third member, ring and pinion, limited slip, etc.
Moser Engineering 9BGICBADBAA - Moser Engineering 9 in. Housing and Axle Packages
$1,214.95
Axle Assembly, Ford 9 in., 33-Spline, Chevy, Pontiac, Camaro, Firebird, 1993-97, Kit
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
