better axle materiel
Old Feb 12, 2012 | 11:26 PM
chevy_dude97's Avatar
Which is better 1541H steel or 4140 chromoly?
Old Feb 13, 2012 | 11:39 AM
matLT1's Avatar
Re: better axle materiel
Could you expand on what you consider to be "better"? Do you want strength, do you want durability, lower cost, etc? Each material has its pros and cons.
Old Feb 15, 2012 | 01:57 PM
Well, I seen the chromoly was more expensive. I found a couple problems with my axles and decided to buy new ones. With chromoly I sappose it would be stronger and more corrosion resistant than the hardened steel? I just don't want to have to replace axles again since my car only has 55K on it... I understand other factors are involved for the reason my axle was bad but I figure maybe the chromoly would help in the future.
Old Feb 15, 2012 | 03:46 PM
km9v's Avatar
chromoly is stronger.
Old Feb 24, 2012 | 01:18 PM
Kevin Blown 95 TA's Avatar
Don't feel too bad about replacing your axles, that whole system of using the axle as the inner race is retarded. Were they worn right there where the rollers were on them?
Old Feb 24, 2012 | 01:55 PM
96capricemgr's Avatar
I wouldn't bother worrying about shaft strength of aftermarket 7.5" shafts. By the time they become the weak link the carrier and gears are going to be a bigger problem.
Old Feb 24, 2012 | 04:04 PM
thats funny you say that, because the component that was warn in my rear was an axle... I understand bearings caused the wear even before they failed but I figure a stronger material would not wear as quick. Im not worried about them twisting just the race surfaces and splines as they where also worn.
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
