noise and rear end shaking from axle play
Old Jan 15, 2012 | 07:51 PM
fallenskater8's Avatar
ok so i just replaced my rear end in my 02 z28 w a similar rear end w trac control and 3.23s which was the same stock setup i had. when i started driving i first noticed the rear end makes a banging chatter type of noise from the rear end when i would hit bumps or harder rough spots in the road. i replaced the shocks shortly after to no avail. when i get up to around 55-60 the car starts to shake from the rear passengers side wheel. i had the wheels balanced and no change. after jacking the car up and pulling on the wheel up down and side to side i noticed i had some play, about 1/8th of an inch. i changed the wheel bearing and oil seal and reduced my play to about 1/16th inch . the shaking still persists but its just not as bad. does anyone have any ideas what could possibly be the problem?
Old Jan 16, 2012 | 08:42 PM
Re: noise and rear end shaking from axle play
update : it seems as if im getting noise from both sides now ! i havent checked the other side for play in the axle yet but i will soon . im looking into possibly the bearings on the insides of the differential housing ( on the outside of the gears) maybe this is causing the problem. anyone that can help me at all i would really appreciate it. this is my daily and im really trying to avoid any possible damage that may be coming.thanks
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
