I need build help
I need build help
I have a 1993 LT with 700r4 stock 3.23 rear trans and k&n and 1.6 comp gold mags 1996 ss block with non-fbody intake.I have hooker cat back and cut out.
I have for parts an extra "freshened" bare block with just crank and caps in it 2 heads that need port, 2 cams comp 305h and a 305 or 306 i don't remember. I also have unused flat lifters and intake.
My goal to get best drivetrain set up I can for money. I will be removing the drivetrain in a few years for a new build.So not wanting to get too crazy though maybe h/c/i. Id like to get best power i can to the street. I'm going to run a N/A build not doing power adders at all including nitrous don't feel it will fit my needs.
My questions:
Can any of my old parts be reused (namely the comp rockers with less than 2k on engine with a rebuild i don't trust)?
Will the 305h cam work if with le or ai heads?
Should I just home port since i have extra set of heads, intake ect?
What cam to use if mine are not good?
Does porting t/b help i've seen mixed results?
Do i need injector swap?
Lastly given parts and budget what whould your build be?
My budget is 1500 to 1900 for engine. see other posts for drivetrain.
My questions:
Last edited by Chevelle70ss; Jan 7, 2012 at 11:17 PM. Reason: moderator suggestion
Re: I need build help
You should split this into two threads - one for the engine and one for the trans. I only left this on LT1 Engine Tech because it had engine components. Generally, a post this long, covering multiple issues doesn't get good results.
CARiD
Sep 30, 2015 05:44 AM
