4l60 swap
Old Mar 3, 2012 | 01:11 PM
red 95 z28 lt1's Avatar
4l60 swap
asking for a friend will a 94 trans am auto trans work in a 95 firbird formula as a replacement?
Old Mar 3, 2012 | 11:08 PM
Re: 4l60 swap
The 4L60 was used up to 93. 94 and up is the 4L60E. There will be a mismatch on the converter lockup, because 94 is a switched lockup, and 95 is pulse width modulated. I believe the wiring harness is different, and the PCM control is different.
Old Mar 5, 2012 | 09:12 AM
12SCNDZ's Avatar
Re: 4l60 swap
Definitely not. The '95 unit is a PWM (Pulse Wirth Modulated) unit, which means it has an extra soolenoid, and a different locj up strategy. It will throw a cose immediately, and go into limp mode...
Frank
Old Mar 5, 2012 | 04:26 PM
Dave89IROC's Avatar
You would need to add a wire to the trans harness and flash your pcm with a 95 tune to use the 95 trans
Sent from my PC36100 using Tapatalk
Old Mar 5, 2012 | 04:42 PM
Re: 4l60 swap
Great thanks my friend was looking for a used trans and had a deal with a unit from a 94 ta but she found one out of a 95 car... Thanks again guys
Old Apr 14, 2012 | 06:32 PM
karkareco's Avatar
Re: 4l60 swap
i have a little something to add..or a question i suppose..can the 94 pcm be programmed to run the pwm trans or do you have to use the 95 in order to pulse width modulate the soloniod?
Old Apr 14, 2012 | 06:44 PM
12SCNDZ's Avatar
Re: 4l60 swap
You need a '95 PCM and wiring harness. The '95 has an extra wire from the PCM to the transmission
Frank
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
