Certain steps to fill a rebuilt auto trans with fluid
Old Mar 15, 2012 | 09:38 PM
chrisv256's Avatar
My transmission mechanic says just pour in four quarts of fluid, crank the car, and then continue adding until full.
Some say to add a quart or two to the torque converter before installing onto the transmission.
Does it matter? Should I add fluid to the torque converter?
Old Mar 19, 2012 | 04:37 PM
chevy_dude97's Avatar
Re: Certain steps to fill a rebuilt auto trans with fluid
YES! If not thats the main source for metalic debrise in a pan. The fins inside the converter. I sugest priming the converter with atleast 2 quarts. Ensure you get both splines lined up installing it. add untill full... start the engine and continue filling untill hot. I believe the converter dependant on size can hold atleast 4 quarts then another 1-2 in the cooler and lines and about 4-4.5 in the pan. Make sure you have enuff to fill it all the way up.
Old Mar 25, 2012 | 10:23 PM
12SCNDZ's Avatar
We put the converter in dry. Put 4 quarts in the transmission when you get everything bolted in. After initial 4, start car for 3 second, and then shut off. Add 4 more quarts, then start car and leave it running. Continue adding until it shows full on the stick. A stock pan 4L60E with a 12" converter will take near 14 quarts.
Frank
Old Apr 10, 2012 | 12:43 PM
Revise: You may want a little in it to lubricate untill the pump picks up the fluid from the pan and sends it to the converter.
Link below: priming a converter from gmperformance.
http://www.gmhightechperformance.com.../photo_13.html
And here is a pic of the internals. My rule of thumb is if you would lube lifters prior to start why wouldnt you lube a converter?
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
Sandersen511
Jan 13, 2015 03:49 PM
rockync7
Jan 1, 2015 05:10 AM
Sarahrope64
Nov 27, 2014 11:17 AM
