Flexplate to stay with 4l60e?
Old Aug 22, 2012 | 05:43 PM
1994BmtZ28's Avatar
Got the defective tranny out of my red Z (in my sig) and am goin' in with the one from my white Z (also in my sig). I know the flexplate is balanced on these f-bodies and was wondering if I should swap the flexplate from my white Z as well with it's 4l60e? I am under the impression the flexplate is balanced to the crankshaft externally. The previous owner of my red Z marked the flexplate/tranny relationship (like I did on my white one) and was thinkin' of tryin' to put the weights in the same position without swapping the flexplates. The last thing I need is vibration or shuddering issues if the flexplate is balanced with the tranny instead of the crankshaft. Any feedback would be appreciated.
Old Aug 22, 2012 | 05:52 PM
96capricemgr's Avatar
Re: Flexplate to stay with 4l60e?
Yes LT1s are "external balance" on the rear BUT they are the same, it is not custom per engine and the flexplate has a dowel pin to the back of the crank so it can only be clocked one way. So I guess what I am saying is you are wildly overthinking and complicating this.
You might look into a "budget performance" flexplate, they really aren't that expensive rather than robbing parts off the other car unless the other one is a project that will need such parts replaced with performance pieces later anyway.
Old Aug 27, 2012 | 03:10 PM
1994BmtZ28's Avatar
Yes, Dwayne you're probably right about over-analyzing this. When I looked at the flexplate in my white Z28 I found it cracked around the mounting bolt holes with pieces missing. I figured I better take your advice and get away from the stock flexplates. I have a Jegs High Performance flexplate coming via FedEx. Thanks for the reply.
Old Aug 27, 2012 | 03:55 PM
Actually the stock flexplate works fine. My advise was more about not robbing Peter to pay Paul
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 01:46 PM
football4life
Oct 4, 2015 07:48 AM
