Used pinion bearing preload?
Old Jun 18, 2006 | 06:46 PM
wrd1972's Avatar
Did a R&P swap. The gears were super quiet yesterday but today I have slight wine on decelaration. I am convinced that it is loose bearing preload.
I am using the Ratech solid spacer and not the crush sleeve. The used bearing preload was around 4-6" pounds, seems light to me. You could feel a very slight amount of drag when turning it by hand.
I can pull it apart and remove maybe .002-.003" from the pinion preload shim pack. This will definitelt tighten it up a bit.
What is the correct used bearing preload for 10 bolts?
Do loose pinion bearings sound like the poblem with decel whine?
Old Jun 18, 2006 | 07:15 PM
jay_lt4's Avatar
Re: Used pinion bearing preload?
right around 15"pounds for used pinion bearings
Old Jun 18, 2006 | 07:20 PM
wrd1972's Avatar
They are definitely loose then, will this cause slight whine on decel only?
Old Jun 18, 2006 | 07:38 PM
fbodyboy's Avatar
yes it will.
Old Jun 19, 2006 | 09:09 PM
wrd1972's Avatar
Well the pinion preload was too light. I ended up removing .008" of preload shim to get about 15" inch pounds of preload. There is a bit less whine on decel.
Maybe the light preload abnormally wore the gears a bit, I put maybe 30 miles on them with this light preload. The pattern was perfect so I dont see how this could happen so fast. Maybe I am wrong.
There is only a trace of whine on accel.
I only drove it a few miles tonight, maybe it will get better as time goes on, but I doubt it.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
