ZF 6 speed in a Camaro?
Old May 31, 2006 | 05:48 PM
supercharged87's Avatar
Will the ZF 6 speed out of a Corvette fit in an LT1 Camaro? If so what modifications are needed? Will the LT1 bellhousing and clutch work? Driveshaft?
Old Jun 1, 2006 | 05:33 AM
5.0THIS's Avatar
Re: ZF 6 speed in a Camaro?
Well, it fit behind the LT1 motor in the corvette. You might need the bellhousing and clutch assembly from one of those cars, but I have no idea if the crossmember is anywhere close, what the overall length is, and if the shifter would fit through the factory hole. Not sure also if you'd have to redo the tunnel to clear the tranny. Not sure why one would even consider doing this for ANY reason... especially when a T56 fits fine.
Old Jun 2, 2006 | 07:24 AM
PoorMan's Avatar
delete
sdn1997rs
Dec 30, 2014 08:30 AM
ChrisFrez
Nov 30, 2014 08:41 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
