Inefficient converter or normal power loss?
Old Jun 7, 2006 | 05:16 PM
big dave's Avatar
I recently had my car on the dyno and found that the car was picking up 40 rwhp just by going into lockup. The converter is a 3200 vig. Another thing I can't figure out is why is my car going through the traps at 5900 rpms when, according to online calculators, I should only be seeing 5500 @ 114 mph. I wouldn't think the converter could slip in lockup.
I have 3.73 gears and 26/10.5 et streets.
Old Jun 8, 2006 | 12:49 AM
blackztpi's Avatar
Re: Inefficient converter or normal power loss?
when racing, your converter wont and cannot lockup. by doing so you'd be losing time and rpm. calculators are hard to believe becuase they don't have all the factors. just like hp calculators from ET's. A car could go 12.3's at 108mph on slicks and it could go 12.8's @108mph and it would tell you that you have 40more hp with slicks. anyway, it probably just missed a variable. i hate calculators. even compression calculators have variables that can trick you a little.
Old Jun 8, 2006 | 01:37 AM
wdtiger's Avatar
That, and the calculators don't take tc slippage into account.
Old Jun 8, 2006 | 06:33 AM
rskrause's Avatar
Moderator
40hp wouldn't be unusual for an unlocked converter. As was said, with stock programming it won't lockup under wide open throttle in thrid gear (I am not sure abnout 4th). And on a drag strip, you wouldn't want it to.
Rich
Old Jun 8, 2006 | 03:54 PM
big dave's Avatar
My converter locks up at the track. It does it on the dyno and when racing. It sounds like it is going into another gear but it's actually the converter locking.
Old Jun 8, 2006 | 03:55 PM
big dave's Avatar
Wink Re: Inefficient converter or normal power loss?
I've debated this with others before who claim it's impossible...til they see it on the dyno. I have a friend with a '94 Z28 also, his too goes into lockup.
Old Jun 8, 2006 | 06:28 PM
rskrause's Avatar
Moderator
In what gear? It "shouldn't" do it in third, which is where you want it when you go through the traps.
Rich
Old Jun 8, 2006 | 08:33 PM
big dave's Avatar
Yes, in third.
Old Jun 10, 2006 | 12:43 AM
84firebird's Avatar
it should lock when you cruise at any rpm to keep the tranny from overheating, there are wiring tricks to disable it though, locking up is usually a bad thing except for fuel economy
Old Jun 10, 2006 | 05:57 AM
big dave's Avatar
The converter locks like it normally would while cruising but it definitely locks up in 3rd under WOT. No tricks were done to the computer or tranny to make this happen.
Old Jun 12, 2006 | 06:43 AM
big dave's Avatar
Well after looking at the thread relating to lockup converters, I see that converters can be programmed into lockup under WOT in 3rd gear. Now whether this was done to mine I'm not too sure but the thread only confirms what I know is possible.
captcorvette
Mar 7, 2015 12:37 PM
97z28k&N
Jan 9, 2015 04:58 AM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
