Tranny swap
Old Jun 9, 2006 | 09:31 AM
MTmace's Avatar
Question Tranny swap
I have a turbo 350 and would like to put a t-56 manual in my 1st gen.
What is involved with this swap?
MTmace
Old Jun 9, 2006 | 12:45 PM
rlax31's Avatar
Re: Tranny swap
could we have some more info on your setup?
Old Jun 9, 2006 | 01:56 PM
MTmace's Avatar
Re: Tranny swap
Not sure what more you need to know.
I have a 350 block, turbo 350 tranny. The car's color is blue.
MTmace
Old Jun 9, 2006 | 02:09 PM
rlax31's Avatar
Re: Tranny swap
hah, sorry, just was a little curious if you had retro-fitted like an LT1 or LS1 in your car.
when I swapped the trans in my 97 from auto to M6, I had to cut a whole in the floor for the shifter, and cut a hole for the master cylinder by the new pedal.
I'm not sure how speed sensors would hook up.
You'd have to make sure you have the correct bellhousing and input shaft I'm sure, along with a shifter, hydrollic clutch setup, pedal(s), clutch, flywheel, and pressure plate.
There should be someone here with some more info.
Old Jun 9, 2006 | 02:35 PM
Re: Tranny swap
Keisler sells T56's that will work on the Gen 1 SBC engines. McLeod sells a modular bell-housing setup that allows virtually any engine to be coupled to the T56. They use the LS1 version of the T56, because it uses a conventional pusher clutch, and not the pullback design like the LT1 T56 uses.
We have a "Drivertrain" forum.... I'll move your post there.
Cam's maro
Aug 11, 2015 07:45 AM
Collinjacobfowl
Jul 30, 2015 09:35 PM
wesley81
Jul 27, 2015 11:31 AM
Boss002
Jul 24, 2015 10:47 AM
