loose flywheel?
Old Jun 3, 2006 | 11:40 AM
Beyonce Knowles's Avatar
loose flywheel?
when I went to get my new tires installed the guy doing the work told me that my flywheel is loose and that I need to tighten the bolts down. He claims to have several built camaros that he races, but I dont much to much stock in that. What are some symptomes of a loose clutch before I pull the transmission?
Old Jun 3, 2006 | 12:11 PM
net_coma's Avatar
Re: loose flywheel?
What prompted him to decide they are loose? If the clutch (pressure plate) was loose I would expect the clutch to slip. Have you noticed any abnormal symptoms?
Old Jun 3, 2006 | 12:54 PM
Re: loose flywheel?
I believe he said he could hear it when he started it up and feel it when he drove it. The car has a relatively new Spect IV clutch in it, which I am assuming is installed correctly. I am noticing a little bit of an unsteady idle/deceleration as well as alot of buffeting that does not seem like normal clutch chatter when letting the clutch out.
Formula Steve
Sep 19, 2023 08:31 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
