LT1 PP vs. LT4 PP. Can I use LT1 PP w/ Mccleod?
Old Jun 22, 2006 | 03:58 PM
Jazsun's Avatar
I am thinking about just sticking w/ and getting a new LT1 PP for my clutch swamp, and using it w/ a mccleod disk. Is this ok? Or do I need to have an LT4 pp?
Whats the major advantage w/ using an lt4 pp?
Old Jun 23, 2006 | 10:31 AM
Jazsun's Avatar
Re: LT1 PP vs. LT4 PP. Can I use LT1 PP w/ Mccleod?
bump
Old Jun 23, 2006 | 12:07 PM
yotaman96's Avatar
should be fine
Old Jun 23, 2006 | 02:30 PM
wrd1972's Avatar
Yes you can.
You might want to resurface it if it is rough.
Old Jun 23, 2006 | 02:36 PM
Jazsun's Avatar
Well I want to know what the advantage is to using an lt4 pp?
Old Jun 26, 2006 | 05:38 PM
Jazsun's Avatar
Anyone? Do I need to use an LT4 PP w/ mccleod single disk? Whats the advantage to using the LT4 PP/TO bearing?
Old Jun 26, 2006 | 05:56 PM
97 6SPEED Z's Avatar
Thumbs up Re: LT1 PP vs. LT4 PP. Can I use LT1 PP w/ Mccleod?
Jazsun, the advantage of using the LT4 pressure plate & throw out bearing is the +20% additional clamping force over the stock LT1 pressure plate.
It's for this reason that almost all aftermarket LT1 replacement clutch kits use the LT4 pressure plate. Hope this info helps?
Old Jun 26, 2006 | 08:04 PM
Jazsun's Avatar
Ya thats helps a lot. Some people said I could use it now I know I shouldnt. Thanks. I wasnt sure if hte aftermarket kits came w/ the lt1 or lt4.
Noer
Feb 28, 2015 11:29 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
