how to upgrade to 3.73?
Old Jun 13, 2006 | 12:24 PM
bldjello's Avatar
i hear everyone saying "time to upgrade to some 3.73 or 4.10 gears" but whats that mean and how is it done?
is it possible on an automatic? and if im correct, i have 2.73 gears because i dont see the first gear on my shift column? correct?
Old Jun 13, 2006 | 12:32 PM
Sweetred95ta's Avatar
Re: how to upgrade to 3.73?
That means going to a lower gear ratio. The lower you go, the better acceleration you get, but you lose some of your top-end speed. It is done by removing the gears from the rear end and swapping in new ones. It is possible on an automatic. If you have 2.73's, then you have a 2 series carrier. I'm pretty sure you can get a 3.73 for a 2 series carrier, but that's as low as you can go. If you want lower (ie 4.10's) then you'll need to get a 3 series carrier.
Old Jun 13, 2006 | 01:04 PM
bldjello's Avatar
oh cool, how much does it cost and how would i go about getting that done?
Old Jun 13, 2006 | 01:14 PM
kick Z tail out's Avatar
If you go from 2.73s to 3.73s you're gonna look like this guy --->
It's not expensive at all.
Old Jun 13, 2006 | 01:31 PM
bldjello's Avatar
hahaha, where and how do i get it done? especially if im gonna be like lol
Old Jun 13, 2006 | 01:45 PM
teke184's Avatar
you have to remove the gears out of the differential on the rear axle, swap in some new bearings and parts, and the new gears. then you have to recalibrate the speedo and shift points to accomodate the gear change.
technically i thought it was illegal to change rear gear ratios according to some kind of emissions laws (unless done by a dealer). altough i know alot of shops do it.
do a google search for gear swaps...i'm sure there are some pictorials.
Old Jun 13, 2006 | 01:51 PM
Where are you located? You should be able to ask around and find someone that sets gears up on the side. It will be cheaper that way. I'd say a good setup guy will cost $150-$200 just for labor, but there are a few key things that have to be done and more than likely you don't have the special tools to do them. Oh, and you will definitely love it. Say goodbye to 50 mph in 1st gear . Is your car an A4 or M6? Either way the speedo will need calibrated and possibly the shift points (A4) as stated above. That's an extra chunk of change unless you have the software to do this.
Old Jun 13, 2006 | 04:30 PM
bldjello's Avatar
ill ask around and see if i can find anyone... if not, anywhere i should look? (im located in woodland hills, CA... near Los Angeles)
also, what do you mean by "Oh, and you will definitely love it. Say goodbye to 50 mph in 1st gear " haha is that meaning itll be better?
and how do i find out if its an A4, or M6
thanks guys =)
one more thing, i picked up new plugs today, and i went to look at the setup is to put em in and WTF how am i sapossed to do that? (i got the car 3 weeks ago) so im just starting all this **** now =)
Old Jun 13, 2006 | 05:11 PM
teke184's Avatar
a4....automatic 4 speed trans
m6....manual 6 speed trans
need any more help?
j/k
as for the difficult plugs, remove the motor mount bolt and jack the motor up 2"...you can get to all the plugs with ease
BY THE WAY
put a signature together so we have some clue as to the year and options on your car. it will GREATLY affect some suggestions on mods.
we don't even know what year the car is
Old Jun 13, 2006 | 05:13 PM
PrplZ28's Avatar
A4 = Automatic tranny
M6 = 6 speed manual tranny
EDIT: beat me to it lol
Old Jun 14, 2006 | 09:55 AM
bldjello's Avatar
how much of a impact will it make hp and torque wise?
also, is my sig. working? =P
Old Jun 14, 2006 | 10:11 AM
TobyZ28's Avatar
Hp Impact = 0
Torque = 3.73 /2.73 = 37% more
Old Jun 14, 2006 | 11:09 AM
bldjello's Avatar
so yea i totally need to get this done now. =) after that how would i give my HP some catch-up, cause id still have stock hp, with almost double torque...?
Old Jun 14, 2006 | 11:30 AM
MyShibbyZ28's Avatar
The torque/horsepower difference will not really matter. The difference is not that much. And it's not almost double the torque. Double the torque would be 100% increase. 37% is a little less than half of what you have now.
For horsepower;
CAI
Catback
Headers
Old Jun 14, 2006 | 11:42 AM
bldjello:
Pacific time is 2 hrs behind me (10 your time = 12 my time). I was in bed at midnight (central). My bad. Just hit me up again on AIM sometime this evening.
