installed twin disk and now car won't turn over
Old Jun 11, 2006 | 08:46 PM
superirocz's Avatar
Well I finished my twin disk mcloud install and a new starter and now the car won't turn over its like its jammed up. Starter is new its trying to turn the car over but its just bond tight. I installed the clutch just like it sayed in the instructions. I have installed 6 clutches in these car and never had an issue?
Old Jun 14, 2006 | 04:12 AM
GONE's Avatar
Re: installed twin disk and now car won't turn over
I just recently had an issue with McLeod....Not the twin disk though....
They have a habit of making the discs TOO THICK.Mine was 10 thousandths too thick and it ran, but I couldn't get into reverse, getting the car in gear was a pain, and so on.
When the disc is too thick, the clutch remains partially engaged and the starter really feels it.
I'd inspect the disk and measure it.
Just my two cents.
Old Jun 14, 2006 | 07:46 AM
96TurboTA's Avatar
Take the car out of gear and try to start it. That will take the clutch out of play. If it starts then there's a problem with the clutch.
Old Jun 19, 2006 | 05:09 PM
1 DWN CAM's Avatar
in a twin the top disk which has the Marcel in it should be no thicker than
.340 but usually between .325 and .330. any more than that and you'll have problems.
Now the bottom disk is a flat design and those should come in between .300 and .315 ish anything more and you've got problems. Pull the disks and check them with a dial caliper. if you have a problem call Don in reworks.
714 630 2764 ext 234. you may be able to get them replaced if there to thick.
Old Jun 21, 2006 | 04:57 PM
superirocz's Avatar
The one bolt that goes into the bellhousing was hitting the presure plate. Luckily there was no damage since the bolt was already jammed up agaist it keeping everything from turning over. All the bolts are the factory bolts but the one is just a 1/4" to long
Old Jun 22, 2006 | 01:20 AM
GONE's Avatar
Are you sure you didn't install a trans bolt in place of a bellhousing bolt?
The trans bolts are about a 1/4 or 1/2 inch longer if I am not mistaken.
LeftoverChinese
Jan 14, 2024 03:03 PM
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
