P1810 code...what to do?
Old Jun 24, 2006 | 10:25 AM
Cmr0z28's Avatar
Was hoping some of you could help me out here...
The past few times I drove the car, the converter lockup has been acting all funny. I would lock, unlock, lock, unlock, etc and then eventually just stay unlocked.
Last night my SES light came on and I got a P1810
-DTC P1810
TFP Valve Position Switch Circuit
I don't know where this thing is located or how hard it is to change. Can anyone please provide some insight? Thanks!
Old Jun 24, 2006 | 10:36 AM
Re: P1810 code...what to do?
Generally a good idea to use an LT1 specific code list, not a generic one. Shoebox has the LT1 OBD-I and OBD-II engine and tranny code list on his website:
http://shbox.com/1/Dtcs.htm
P1810 = Pressure Switch Assembly (PSA) Circuit Malfunction
Not that I know where that is.... but at least you have the correct code description.
Old Jun 24, 2006 | 11:30 AM
james007moore's Avatar
The TFP switch is located in the trans pan, attached to the valve body. It is very simple to replace, check to make sure it isnt unplugged, or any wiring is rubbed through. It is held on with (2) 8mm bolts and (3) 10 mm bolts...If all the wiring is okay, you may want to clean off the sensors and try it before you replace it. Beware that sometimes the sensors come apart when you remove it from the valve body..the rubber o-rings stick to the valve body.....
james
Old Jun 24, 2006 | 12:05 PM
Cmr0z28's Avatar
Thanks, I'll give it a shot once I figure out why my belt just flew apart and got chewed up around my AC compressor.
rocks_n_stones21
Mar 14, 2007 12:15 PM
rocks_n_stones21
V6 Tech
Mar 12, 2007 05:56 PM
cpt_bimes
May 9, 2004 09:16 PM
