How can I find out what my...
Old Jun 17, 2006 | 10:25 AM
93Phoenix's Avatar
I have a 93 T/A with a 6-speed obviously as you'd know from my sig. However 93 had 2 different gearboxes offered... the M29 that came with the 3.23 car and the M28 that came with the 2.73 cars. How can I find out what my gear is, I'm getting a tune from MadZ28 but I don't know what my differential gear ratio is.
TIA,
Andy
Old Jun 17, 2006 | 10:56 AM
RichardZ SS's Avatar
Re: How can I find out what my...
Just a guess here, but I THINK you should be able to look at your option codes inside the drivers door. It will either be GU2, GU5 and ?possibly? GU6 maybe? In any case, the GU2 is the option for the 2.73 gear ratio rearend. Another method that is foolproof is to remove the rear dif cover and count the number of teeth on the ring gear and the number of teeth on the pinion gear and divide em.
Old Jun 17, 2006 | 11:07 AM
Both the tranny code and the gear code should be on the build tag.
Old Jun 17, 2006 | 01:11 PM
93Phoenix's Avatar
Where's that
I looked on the drivers door, saw no GU2 etc.
Old Jun 17, 2006 | 01:45 PM
Originally Posted by 93Phoenix
Where's that
It should be in the glove box.
Old Jun 17, 2006 | 03:28 PM
93Phoenix's Avatar
Okay yea I have GU5 so that's the 3.23 then right?
Old Jun 17, 2006 | 04:10 PM
brians96Z's Avatar
Yes, you have 3.23's if it is a GU5. I don't think the 2.73's were ever available in a M6 car, am I correct?
Old Jun 17, 2006 | 04:52 PM
anaik's Avatar
http://www.f-body.org/faq/4/4_3.htm
Old Jun 18, 2006 | 10:37 PM
93Phoenix's Avatar
Originally Posted by anaik
According to that I have a 3.23 auto?
Old Jun 19, 2006 | 02:01 AM
19z28camaro02's Avatar
In 1993 You CAN have a 2.73 with the M6, IT IS POSSIBLE, check RPO codes in the glove box, then go to http://www.camarosource.ca
Old Jun 19, 2006 | 06:30 AM
anaik's Avatar
You should have the M29 code along with the GU5. That link says GU4, that's a typo.
Old Jun 19, 2006 | 11:00 AM
Ditto... GU4 is the 3.08's used in the V6's.
HectorM52
Jun 23, 2016 08:42 PM
Z28Freak86
Apr 28, 2015 10:35 PM
CARiD
Apr 8, 2015 08:08 AM
mattstrike
Mar 11, 2015 07:33 PM
Sarahrope64
Nov 27, 2014 11:17 AM
