12 bolt rebuild kit?
Will this kit work to rebuild a Moser 12 bolt?
http://store.summitracing.com/partde...5&autoview=sku
It says for 30 spline axles but I dont see why it would be limited to a 30 spline axle... I am rebuilding a F-body12 bolt with a 33 spline spool. It needs everything, gears, pinion and axle bearing, seals ect.... Is the kit I need to buy? I cant find anything else listed for a 12 bolt except a basic gear install kit.
Brian
Brian
Re: 12 bolt rebuild kit?
Originally Posted by rskrause
Get what you need from the outfit that set up the 12-bolt in the first place.
Rich
Rich
yeah I'm just going to call Moser tonight and have them send me everything I need. Thanks for the help.
Actually it will make a difference; Different spline axles are different diameters; thus the axle bearings and seals are different. Not to mention the Moser and Strange 12-bolts use housing ends similar to a Ford 9" where no c-clips are needed unlike most stock 12-bolt axles.
Sergio
Jan 27, 2016 04:27 PM
armedtrigger
Feb 24, 2015 08:30 PM
