Where to get clutches for stock 10 bolts
My clutches are shot in my 94 10 bolt and I just put $400 into the rear so I don't want to spend even more money to buy a eaton unit or spend money that I don't have for a 9" or a 12 bolt. Anyone know where to get them at other than the dealer? They wanted a rediculous amount for a rear end overhaul kit.
Re: Where to get clutches for stock 10 bolts
many af dealser pick up a chevy mag and go to the back .........Ring and Pinion 1-800-321-6871 try them if nothing they should be able to get you a number that can help
until then happy one tire fryin
Thanks I'll give them a try. It sucks getting more power and not being able to use it from the start. I left 110 ft of rubber and had to let off because there was a curb. I looked back and it was a one wheel peel .
If your 94 still has the stock diff, then it's an Auburn which is not rebuildable. You're gong to have to buy a new diff. But don't put the crappy Auburn back in. You might be able to find a Zexel unit in the classifieds or on ebay for a decent price.
Originally Posted by wrd1972
Auburn will swap them out for around $125 or so. They are not end user rebuildable.
http://auburngear.com/aftermarket/dr...EX_Program.pdf
Can you get the zexel diff with series 2 carrier? I'd imagine that they wouldn't come with gears, but they might if it is a used unit I guess. I guess the only other option is to look for a used rear with 3.73's and hope their limited slip is in much better shape.
