ford 9 inch
ford 9 inch
thinking of geting a ford 9 inch.what are the pros and cons.heard you loose power.also can you keep the limit slip aspect that the camaros got.how does it work.also do i get the whole housing or just the rearend.also wanting to get a stronger drive line to hand 6-700 hp.is stock lt1 drive line ok or what can i do.
Re: ford 9 inch
The mechanical power losses published in a tech article in National Dragster:
Dana 60 - 5%
GM 12-bolt - 7%
Ford 9-inch - 10%
I believe the 9-inch is heavier than the 12-bolt.
The 9-inch offsets the pinion shaft to one side, and lowers it 3/4" compared to the 12-bolt, making drivesahft alignment more problematic, but not unsolvable. It requires a torque arm with a set of offset mounting holes. You will probably need to beat in the DS tunnel to clear the top of the rear TA mount. You will probably need a new DS.
I don't think they offer 3-channel ABS on the 9-inch.
You can't get a posi above 31-spline axles, so you have to go to a locker or a spool. The 31-spline posi is an Auburn unit. With a 12-bolt, you can go to 33-spline axles with a HP Eaton.
The 9-inch allows you to swap center-sections for quick gear changes (slowed a bit on a 3rd or 4th Gen because of the TA mount)
There are more options available to appreciably strengthen the 9-inch for applications over 1000HP.
The 9-inch offers a wider selection of gear ratios.
For 700HP, the 12-bolt will be OK, unless you spend every weekend at the track and make numerous runs with 6K clutch dumps on super-sticky tires. You will definitely need a new driveshaft.... Spohn HD, Dennys "nitrous ready", Mark Williams 3" chrome moly.
The stock clutch will not stand up to that kind of HP, and the 4L60E will need a major (near-miraculous) rebuild to stand up to it. The T56 will take it, but you might want to upgrade some of the internals and the input shaft.
Dana 60 - 5%
GM 12-bolt - 7%
Ford 9-inch - 10%
Re: ford 9 inch
Originally Posted by jmh96z28
wow.thanx.so the stock rear end on a 96 z28 is a 12 bolt.i also have 4.10 gears
