01 Z-28 10 Bolt in 96?
Old 06-22-2006, 08:14 AM
doo_man's Avatar
Want to put rear end with 4.10's in my 96 z-28, found one out of a 01 z-28. Is this a direct "bolt-in", is there anything I should be concerned with? No brakes just axle housing/assembly.
doo_man is offline
Old 06-22-2006, 09:00 AM
Re: 01 Z-28 10 Bolt in 96?
You also need to make sure both cars have the same sensor system for the ABS. If a car has only ABS, there's a single sensor on the top of the diff housing. It a car has ABS + TCS there are wheel sensors on both ends of the axle housings. You can't interchange them unless both cars had the same sensor setup.
Injuneer is offline
Old 06-23-2006, 07:59 AM
doo_man's Avatar
Mine has TCS, I will check on his - Thanks!
doo_man is offline
Old 06-23-2006, 10:50 PM
doo_man's Avatar
Turns out his does not have TCS any way around this?
doo_man is offline
Old 06-24-2006, 09:37 AM
doo_man's Avatar
Is it that easy, or does it effect the ABS? I'm having issues with it now, LOW TRAC comes up and the ABS off light is on most of the time anyways. How do you determine which is which(rear end that is). I went under today and the harness looks like it's be "modified" one wire cut-off and other(s) taped. Just bought car, it's possible it's already been changed out? I can't seem to get the warnings light to turn off, they do intermittently but for very short periods.
doo_man is offline
F'n1996Z28SS
08-23-2023 11:19 PM
Victor Lamb
08-26-2017 02:52 PM
RUENUF
03-13-2016 03:39 PM
maybe2fast
03-16-2015 09:45 AM
Quick Reply: 01 Z-28 10 Bolt in 96?
