How to BANG the pinion out of the rearend housing?
Old Jun 18, 2006 | 08:02 PM
wrd1972's Avatar
The way I bang the pinion out of the housing is by placing a pinion nut on the pinion gear and pounding it with the 3 pound bay sledge hammer. As you know it is the front bearing providing the fight. The nut protects the pinion from hammer damage.
The problem is now my expendable nut has been beet to death.
Does anyone have a better way of doing this?
Old Jun 18, 2006 | 10:29 PM
Ricardo's Avatar
Re: How to BANG the pinion out of the rearend housing?
I use the same procedure. The only difference is that I use a solid piece of brass barstock to beat the pinion nut. About 2" diameter 3" long.
Old Jun 19, 2006 | 04:33 PM
97FormulaWS-6's Avatar
The nut should be replaced once it's been removed anyways, they're a one install type part.
Old Jun 19, 2006 | 09:01 PM
wrd1972's Avatar
I just reverted back to the nut on the end and banging it out with a 3 pound sledgehammer.
Worked just fine once again.
Old Jun 26, 2006 | 09:22 AM
Dave C. '97 Z28's Avatar
I back off the old nut until it's past the threads, and then hold a piece of 2x4 in front of it while I beat it out until it's loose, then remove the nut and pull it out.
-Dave C. '97 Z28
Old Jun 26, 2006 | 01:53 PM
StudyTime's Avatar
Be careful doing this. Make sure you screw the nut on more than just a few threads. Ask me how I know this? Yes, I ruined a ring & pinion by making this stupid mistake when I was younger. It was threaded on maybe 3 threads worth, and I inadvertantly hit it at an angle. The pinion nut cocked to the side and took the threads off the pinion.
Ben T.
Old Jul 1, 2006 | 07:13 AM
526 SS 96's Avatar
Just buy an air hammer and the pointed bit. Life will be much easier.
Jeff1904
Jun 5, 2016 05:00 PM
Jake Bialke
Sep 24, 2015 11:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
War Engine
Aug 21, 2015 05:28 AM
