View Full Version : Drivetrain
- best stage 2 clutch to buy?
- Attn tranny pro's, need rebuild quote and parts opinion.
- What torque converter bolts did you guys use to install your TCI converter?
- Can I put a older 700R4 in my 94 Z28?
- Does a pressure plate need balancing?
- transmission coolant lines
- TH350 Conversion Ques.
- Need help right now, rear end axel removal
- Rack and Pinion who??
- Need help! Urgent! With tranny pull
- Transmission mount??
- Stock 10 bolt w/ MT Street ET's (Not radials), anyone done it?
- M6 conversion people in here... my firewall is cracking!
- do you have ay tips or tricks to help me intall my trans oil pan gasket thing
- axle install?
- Roller pilot bearing install?
- tko into auto 90 iroc
- how MECHANICALLY difficult is a clutch install?
- rear end options....400rwhp
- Stock 10 bolt hold up to HOT CAM?
- LT1 M6 Trans Sticker question
- resurfacing and aftermarket flywheel?
- A4 Transmission Noise
- 2 thumbs up for GM gears
- Rear end gear question
- Rear swap
- 7.6" ????
- new carrier install
- Wheel hop after new driveshaft
- tranny slipping
- 94 transmission
- Why is manually downshifting an automatic trans so bad?
- Is a stall converter bad for your trans?
- What is a used 94 Z28 rear end worth??
- ABS INOP after 12-bolt install
- Carrier bearing swap.....Real quick question
- cheapest 12-bolt
- torque converter info
- transmission problems i think
- Chances that flywheel is cracked?
- Does a trans cooler help alot
- Will 95 4L60E work in 96?
- 4:10 gears on a A4
- T-56 fluid question
- B&M Ripper console interference problem?
- Stall Prices?
- A4 to M6 and back?
- Mono to Multi Springs
- Replacing my clutch... Need some help
- 67-69 Camaro rearend measurement
- Need help with tranny pull
- installed STALl. now cant do a burnout!?
- angry reverse burnout beat up my car
- Big 4L60E Problems!!!
- 700r4 pan bolt torque specs
- What will this stall fit?
- strange 12 bolt into v6 shell?!
- Disc thickness
- Fluid for Eaton
- SPEC stage 4 or SLP clutch?
- 3200 B&M converter in 94 4l60E tranny, now it wont move till 4 krpm
- SLP clutch OK without SLP flywheel?
- Transmission QUICK Question!!
- Converter that's the most fun to drive
- just lookin for some opinions... 97 Z28 m6 w/2.73 rear(blea!)
- weird drive line issue cant seem to figure out
- t56 fluid.....
- Spec 2 hold 425Rwhp?
- is this a good torque convertor?
- spec steel flywheel?
- t56 problems
- 4th gear synchro
- SLP Clutch
- Review on my dealings with CPT
- This may sound stupid
- 2nd Gen camaro rear end specs: need some info please
- 94 95 4l60e torque converters interchangeable?
- Fuddle Racing converters
- Cracked Flexplate??? ON AN AUTO
- In the middle of pulling out the tranny, a couple Q's?
- Please READ
- Best Way To Build A Decent Rearend Without A Change Out?
- Gen 1 2 400cid sbc bolt pattern same as LT1??
- gear selector problems
- 700r4 swap to th350
- Converter suggestions?
- How much for a new syncro and bearing?
- TH350 Stuck in drive..still
- Pilot Bushing Vs. Bearing
- 1996 auto 4.11 or 4.56s
- HELP....700r4
- WHAT HAPPENED???? clutch pictures
- 12-bolt vs 10-bolt dyno results
- Which stall to get??
- New clutch....failing! Help!
- What's wrong with my 700r4?
- 12 bolt questions... need help ASAP
- rear end and tires question...
- i need help!!!
- Anybody use M1 Ow40?
- thinking about beef 'N up the Trans... suggestions?
- Need help ASAP on 12-bolt install
- how much stall do i need? (4.11s, gm847/1.6s, heads/cam/dyno tune)
- Can a 4L60-E be built to handle ~800rwhp???
- Need Help FAST!
- Flywheel, clutch, and pressure plate? Which brand?
- Best Stall With 3.23's
- how do you unlock 1st gear???
- transmission rebuild???????
- torque arm bolts for moser 12 bolt
- Performance T56 Rebuild?
- Tranny mount?
- Tranny ? reverse
- Anyone try a Fuddle converter?
- Spec 3 installed on 2000 TA
- TH350 conversion Kit
- zo6 tranny gear set???
- TH350 Swap
- what aluminum flywheel?
- Pack a tranny?
- What Clutch Setup on my 383?
- What clutch w/ my 383????
- Strange 12 bolt Noise ???
- brake help and rear end
- 3.23 worth changing to 3.42?(1997 Z28)
- Gear selection with my setup..
- guys i need your help..... please
- Please Help, PRNDL switch question for auto tranny
- clutch problems in my truck?
- tranny slipping
- Torque Coverter Installation!?!?!
- Flushing Trans cooler lines??
- rear end covers
- 4l60e for t56 swap,central,ny anyone interested?
- LT4 clutch users.. how much power uve gotten/seen
- Question
- I need a hardcore 700r4 person's help.
- Clutch pedal has 4 inches of play???
- Anyway to prevent rear end problems?
- Will a new stall help in all rpms?
- Gears or new Rear?
- Adjusting Shift Lever On 700R4??? HELP please!
- clutch connection help
- rear end
- 3.73 or 4.10 in 2 carrier
- Carrier for Rear end gears
- Torque Converter
- 4l60E getting old but i need info...
- Rebuilding a tranny need info
- Need part # for LS driveshaft yoke
- Stock converter tranny specs?
- tci race rebuild kit
- Clutch pedal/master cylinder rod retaining clip??
- need help th350
- TH350 problems
- LT1 stock torque arm length = ??
- 1999 SS Camaro tranny Instillation
- Is 1le driveshaft thinner than ls1 driveshaft.
- Problems
- Rearend Howling
- Mcleod and tranny problems
- 98-00 Master diff than 01-02?
- Are stock diffs rebuildable?
- Need answers can't remove differential
- what happens when pilot bearing breaks?
- overall driving with 3.73s opinions wanted/questions
- Flywheel
- Gears and a Moser Rear End?
- Am I getting ripped off?
- Driveshaft is hitting tunnel and getting carved!!!!
- Transgo Shift Kit vs. PCM Tuning
- Shifts with no clutch pedal depression?
- how quick was your tranny removal?
- where can/should I get the rear end oil additive?
- 93 speedometer gear question
- Synthetic Oil
- transmission or ecm problem... wont upshift at WOT (long post)
- Exciter rings
- Clutch problem-Flywheel jammed?
- i'd appreciate some urgent feedback about my spec stage 3
- Stall converter cause transmission fluid leak?
- transmission problems...rebuild
- What tools are needed to do a gear change?
- Pinion seal...what size socket?
- Rolling when in park (car off).
- Anybody's Torsen carrier noisy coming off the throttle?
- tranny wont shift
- New gears dont know org gears
- Good strong rear? clutch?
- 95 z28 auto is rearend gear diff then a t56?
- tranny not shifting
- High Stall Torque Converter vs Taller Rear End Ratio.
- Is this my clutch wearing out already?
- Clankidy clank...then abs inop
- 5 speed borg warner
- clutch options
- rear end noise? '96 A4
- Traction Control
- Differential cover with an Add/Drain spouts, exist?
- 9inch Posi Options?? Have a spool and HATE it!
- How strong is the t-56?
- which clutch pack kits for a 4l60e
- How much PSI does transmission produce?
- Best price when purchasing upgraded T56
- 5 speed questions
- Differential Torque Spec?
- rear posi and gear install
- TH400 with manual valve body not working properly
- 10 bolt durability
- Friends car stuck in drive
- mobil 424!
- Gears or a Bigger Cam/ New guy to gears
- Slow shifting 700R4
- Did I "smoke" my clutch?
- Real Bad Vibration
- Rearend break in process??
- Pro 5.0 Shifter
- flywheel info
- Moser Rearend Vibration
- What is the best clutch for 1998 T.A.
- Cpt Transmission Race Built Tranny
- gearvendears
- Spec 4 clutch/SLP flywheel install, rubbing pressure plate!
- Brand new SPEC III slipping.....help!
- humming sound when driving????
- Starter not disenguaging fast enough after A4 -> M6 Swap
- Strong 4L60E
- 1995 Z28 Traction Control Option?
- having t-56 rebuilt, should i beef it up?
- Clutches
- To rebuild/replace my 4L60E, that is the question
- Differential Pinion Shaft Hole
- stock rearends
- ? on posi rear end
- tranny mount seems shot at 48K miles on 94Z A4
- Tranny Swap
- Is my rearend ruined?!
- Torque Converter Or Not?
- what could this be...??
- Clutch install problems continue.......!
- 4CH rear into 3CH car???
- th350 performance fluid reccomendation
- Moser 12 Bolt or Strange 12 Bolt
- tranny's out, should i rebuild it?
- Th350
- spec stage 4 noise during break in?
- 4L60E pan
