Need help! Urgent! With tranny pull
Old Apr 15, 2005 | 08:42 PM
raxxus's Avatar
I'm pulling a tranny on a 95 ta 6-speed. I'm pulling it off the bellhousing first, and I have everything apart. It's an inch or so from the bellhousing and won't budge. I already disengaged the clutch fork by pulling back towards the rear before I even started taking off the bolts to the bellhousing. Is there something else I need to do, or just give it all hell? Thanks fellas!
Edit:
Ok, the clutch fork looks like it's still attached, even though I pulled it back to disengage it? Where the input shaft goes in, theres a lip and the end of the fork is on that. Did I not disengage it? Please someone help soon, my brother is supporting the tranny with a floor jack!
Old Apr 15, 2005 | 10:10 PM
OBE1 95Z28's Avatar
Re: Need help! Urgent! With tranny pull
The clutch fork pulls back about 2 - 3". It should be flopping around when you have it all the way disengaged. Try pulling it towards the driver's side.
Old Apr 16, 2005 | 12:29 AM
raxxus's Avatar
Thanks man! Got it! =)
Magenta_Hearts
Mar 29, 2017 08:54 PM
dylan1303
May 22, 2015 12:24 PM
BigWil
Mar 29, 2015 12:24 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
