Starter not disenguaging fast enough after A4 -> M6 Swap
Old Mar 26, 2005 | 07:08 PM
ZugDud's Avatar
Hi guys, I swapped the 4L60E in my LT1 wagon for a T56 and everything works great except that the starter grinds for a second or two after the car starts. I used a spec billet flywheel...when starting it doesnt make any abnormal noises but once started its like the starter isnt disengauging fast enough as if i was turning the key after the car has already started.
I've tried the following:
loosening the starter and pushing the back of it as i tightened it to prevent preload forward - same result
I shimmed it 0.020 - same result
shimmed it to 0.040 - same result
shimmed it to 0.060 - same result except instead of a 2 second grind its a 0.5 second grind...pause....0.5 second grind
shimmed to 0.090 - starting sounded wierd and once it started it did the grind pause grind again...
I dunno what to try next, my flywheel teeth look perfect still...thankfully ...so did the starter gear.
Any ideas or has anyone else experienced this going from flexplate to flywheel? thanks
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
maybe2fast
Apr 23, 2015 08:55 AM
maybe2fast
Mar 16, 2015 09:45 AM
canbaufo
Feb 24, 2015 10:27 AM
maybe2fast
Feb 5, 2015 05:14 AM
