Clutch pedal has 4 inches of play???
Hi,
Im having an issue with my clutch pedal. I never really knew anything was up with it till I started working on a friends 94 T/A. I got in his car and noticed that the clutch pedal was around 4 inches higher than mine (almost even with the brake pedal) So I got in my car and looked and sure enough the pedal is around 3 to 4 inches closer to the floor. So I put the toe of my shoe under the pedal and pulled up and there is about 4 inches of free play befor it stops at the top. Whats up with this?? Is my clutch master cylender bad? Or have a bent my clutch pedal stabbing gears?? Im kindof at a loss here, cause everything seems to work ok but the pedal is just really low. Thanks for all your help.
J.
J.
Re: Clutch pedal has 4 inches of play???
Did you check your clutch slave reservoir? Its the small one next to the brake fluid res. Your slave cylinder might be going bad, too. I had to swap mine out last year. Good luck!
Yeah I checked to make sure it was full on fluid, and no the clutch is not stock. I have a SPEC stage 4 clutch with about 6,000 miles on it. Im guessing the master cylender might be bad, but Im still open for suggestions. Thanks
J.
J.
Noct
Jul 14, 2015 01:18 AM
whitehooptie
Jul 12, 2015 06:10 PM
