transmission coolant lines
Old Apr 16, 2005 | 07:54 PM
ViperXx's Avatar
Does anyone know of a tool or a method to tighten/remove/reconnect the transmission coolant lines? I hooked them up when I installed the transmission and they are leaking BADLY. Any suggestions? Thanks!
Old Apr 17, 2005 | 07:36 PM
OBE1 95Z28's Avatar
Re: transmission coolant lines
A standard line wrench works. Make sure you start them by hand so as not to get them cross threaded.
Old Apr 17, 2005 | 07:58 PM
bing101's Avatar
Disconnect em, and clean em up real well, chase the threads with a fingernail and paper towel, if they are gunked up with old tranny fluid when you tighten up they will not seat all the way.
Male sure you push the flared fitting all the way in first before you tighten down the fitting.
As much as other people say no.... teflon tape if used sparingly and installed in such a manner as to not allow ANY to get in tranny and clog valve body (if auto) will help seal any imperfections, just one wrap near the top of the threads farthest from the end leave a 1/16 or 1/8" gap with no teflon there.
Old Apr 18, 2005 | 12:11 AM
ViperXx's Avatar
Alright, thank you both. Also, as for the line wrench, I looked around AutoZone for something like that, would it be the same as a flare wrench (I think thats the name of it). I have a few of those, but the problem I'm having is getting ANYTHING up there.. Such a tight space. Someone once suggested "crows feet" or "crows claws", I haven't tried them yet, but I am seriously considering that.
Any thoughts?
Thanks again!
Old Apr 18, 2005 | 02:43 AM
Spinner's Avatar
Line wrench and flare nut wrench are the same thing
calaban
May 18, 2020 06:43 PM
Apr 16, 2015 09:57 AM
jackpawt883
Feb 26, 2015 09:04 PM
Jazsun
Dec 29, 2014 12:14 PM
