Stock 10 bolt hold up to HOT CAM?
Old Apr 15, 2005 | 10:16 AM
TireMarx723's Avatar
Will the stock 10 bolt hold up to a LT4 HOT CAM car on big street tires, no slicks, and 4:10's, wIth say a SLP clutch??
Old Apr 15, 2005 | 01:22 PM
izzyz28's Avatar
Re: Stock 10 bolt hold up to HOT CAM?
On street tires I would say most likely it'll be fine as long as you don't drop the clutch at 5K on a reall well-prepped track. I still slip the clutch a little rather than dumping it when I launch, and the rear has held up fine. Shock loads are what kills a rear end, so even if you had 500 HP you'd probably be ok as long as you don't abuse it on the starting line too bad.
Old Apr 15, 2005 | 10:56 PM
Compstall's Avatar
It's a crapshoot. You either got a good one or find out sooner than later.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
jmzlt1
Mar 13, 2003 07:26 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
