guys i need your help..... please
Old Apr 6, 2005 | 07:38 PM
warhead20022002's Avatar
ok here is the deal i have a 98 z28 and the differential was replaced around 6 months ago with a rebuild one. now the right seal is leaking bad so i have gone to napa, autozone, like 3 different places to look for it. and i find it now the problem is that the one i find is 2 times the size of the one i took off now it wont fit. and they tell me that maybe because that differential that was installed belonged to another car or truck but until i know to what?, they cannot help me now all i have is some numbers that i found at the bottom of the differential.
it is a limited slip GM 5 it has a serial#26041414 10 bolt 7.5 thats all i know
i dont know if they made different models or it changes by the year.
Old Apr 6, 2005 | 07:44 PM
EviLZ28's Avatar
Re: guys i need your help..... please
Look for a number on the old seal. Usually they have a number on them. The parts store can cross reference or even match up the part number.
Old Apr 6, 2005 | 08:18 PM
no number on the seal i looked all i know that it is a small seal at least 1/4 in thick
Old Apr 6, 2005 | 08:45 PM
EviLZ28's Avatar
I just looked up the part number of the seal and it is the same for all 93 to 02 rear ends disk or drum. Gm# 26069139
Old Apr 6, 2005 | 09:23 PM
i went to a website where it says that there is 2 different types of seals with different types of outside diameters one has a diameter of 2.25 and another with a diameter of 2.535
Old Apr 6, 2005 | 09:52 PM
EviLZ28's Avatar
Are you sure the seal you are getting from the parts store is for the axle and not for the pinion gear? I have had this happen to me before. The parts store guy tried saying it was the axle seal and I looked at the screen myself and seen he in fact gave me the pinion seal. I have looked all over and only see one number for a axle seal for a 7.5 and 7.625 diameter rear. Timken seal Part# 8660s fits all F-body's , S-10's, Even Impalas. It is a common brand in most parts stores. Who told you that axle seals have different diameters for a 7.5 rear? I have not seen anything for a different diameter axle in these rears.
Old Apr 6, 2005 | 10:04 PM
the timken seal is the first one that i got at autozone. and it didnt fit i dont know why everywhere i ask they give me the same size one. but the thing is that the one i took off is half the size of it. the plastic part is the same but the outer metal part is the one that is big and it wont fit in place. so i guess that that differential doesnt belong to a f body. or an old one maybe a 89
Old Apr 6, 2005 | 10:17 PM
EviLZ28's Avatar
Well I am not sure what you can do then as I looked up from 82 up axle seals and they all use the same part number, even the 7 3/4 aussie 9 bolt. Where did you get the rear end from?
Old Apr 6, 2005 | 11:07 PM
i had warranty on the car and the original all the bearings went out and messed it up so they replaced the whole differential. so i am going to give them a call to see what they can tell me. but thanks for your help. i will keep you updated.
Old Apr 7, 2005 | 02:29 PM
ok i pulled it apart and i see 2 seals it has a seal then the bearings then another seal is there different names for each seal.:????????
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
