M6 conversion people in here... my firewall is cracking!
Old Apr 15, 2005 | 05:34 PM
trax's Avatar
Exclamation M6 conversion people in here... my firewall is cracking!
I had to rebuild my McLeod master cylinder yesterday. When I removed the hydraulics, I noticed something crazy... the firewall was cracking right around the area where I drilled the holes for the master cylidner! I'm guessing I'm gonna have to get it welded and then put some kind of metal plate over this.
Anyone else have this problem? How did you remedy it? Thanks!
Old Apr 17, 2005 | 11:32 PM
Ryan94ZA4's Avatar
Re: M6 conversion people in here... my firewall is cracking!
Is the bracket that hangs down off the pedals on the firewall where the nuts go? The bracket acts as a reinforcement. If not, there's your problem.
Old Apr 17, 2005 | 11:40 PM
ShawnLT4Z's Avatar
dang... i am in the process of doing this swap right now. i hope this doesn't happen to me.
Old Apr 18, 2005 | 11:13 PM
trax's Avatar
The bracket is there, and it still cracked. Turns out this is a common problem with T56 conversion cars. Doesn't happen to everyone, but it still happens to many.
The solution: I went to Ace and picked up some 1/8" weldable steel for about $10. Cut it into a shape that gave the maximum surface area, and then mounted it between the firewall and the pedal bracket.
Pedal is now ROCK SOLID and gives a great overall feel, all the way up to 6200 RPM
2QUIK6
Sep 17, 2016 02:31 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
RobFlag
Aug 29, 2015 11:40 PM
gelbza
Jul 12, 2015 08:10 AM
