LT1 stock torque arm length = ??
Old Apr 3, 2005 | 01:34 PM
Patrick96Z28's Avatar
Question LT1 stock torque arm length = ??
I tossed the old one and no longer have a reference. I have been playing around with adjusting my Edelbrock torque arm so much that I need a reference on the length of a stocker so I can start all over again. Anyone know the length of one of these?
Old Apr 3, 2005 | 02:53 PM
fireman's Avatar
Re: LT1 stock torque arm length = ??
Mine is sitting on my garage floor, can measure when I get home.
Old Apr 3, 2005 | 04:10 PM
perfect, let me know, I'd really appreciate it, thanks
Old Apr 3, 2005 | 04:48 PM
simple's Avatar
delbrock makes an adjustable TQ arm?
i thought they only sold the non adjustable tubular one....?
Old Apr 4, 2005 | 07:29 AM
yup, they make an adjustable one
Old Apr 4, 2005 | 12:32 PM
Why not slap an angle finder on it and adjust it to the desired pinion angle? Why do you need the stock length (which is "variable" because it slides in the bushing)?
Old Apr 4, 2005 | 02:46 PM
I was told in the past not to mess with the length, and I have successfully not listened. I'm just trying to eliminate all the what if's right now. Should the TA slide in and out a little? I am trying to eliminate my LS1 driveshaft from hitting the parking brake cables in the tunnel. I'm guessing that because I messed with the length that maybe that is what's causing me the problem. I am renewing my bump stops as well. Under torque load right now I'm chewing up my DS. Maybe my TA is set too short?
Old Apr 4, 2005 | 05:34 PM
fireman's Avatar
55" exactly, at the longest point.
Old Apr 4, 2005 | 05:37 PM
fireman's Avatar
Or 51 1/2" from the front to the forward most rear bolt hole.
That make sense?
Old Apr 5, 2005 | 11:20 AM
Makes sense to me, I've been down there a miliion times,...thanks man. I'll start from scratch now.
87Aerocoupe
Jan 10, 2015 07:27 PM
tubby
Oct 13, 2003 09:16 AM
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
