do you have ay tips or tricks to help me intall my trans oil pan gasket thing
Old Apr 15, 2005 | 05:20 PM
jamilz28's Avatar
do you have ay tips to help me intall my trans oil pan gasket thing
do you have any tips or tricks to help me intall my trans oil pan gasket thing
i did it 3 mounth ago and i messed it up and it is leaking Tranmission fluid. i just want to know if you have any tips to make sure the gasket is sealed well and will not leak
Old Apr 15, 2005 | 06:21 PM
hatredizm's Avatar
Re: do you have ay tips or tricks to help me intall my trans oil pan gasket thing
Make sure your pan is clean and only use a light amount of gasket sealer. Also be sure and NOT tighten the bolts down too much as to bend/warp the pan. That will make it leak also.
Old Apr 15, 2005 | 11:03 PM
jamilz28's Avatar
i dont think you need gasket sealer do you???
Old Apr 16, 2005 | 07:29 AM
pearlpurple's Avatar
I use RTV just to set the gasket. It isn't needed for sealing.
Before you go to put your filter in,, put a little bit of RTV around the pan place your gasket and leave it sit for a bit, that way when you are replacing the pan the gasket is easier to keep in position. I will even put someof the pan bolts in the holes to keep the gasket in position.
I think the biggest mistake most people make is over tightening the bolts.
I also work my way with the bolts from one side to the other to not have a "wrinkle" in the gasket.
Old Apr 16, 2005 | 12:39 PM
blown94's Avatar
use a 1/4" ratchet with an extension when tightening the pan to prevent overtightening and just snug down with moderate torque. The small size of the ratchet will help pervent overtorque. As for sealant, I dont use any and i work in a tranny shop. all that does is lube the gasket to spit it out. Get yourself a quality gasket for starters, not that thin cork one. After about a 1/2 dozen heat cycles, get under there again and just snug up the bolts and you're done.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
