Rolling when in park (car off).
Old Mar 30, 2005 | 10:47 PM
blueta's Avatar
Well I got finished installing my lt1 into my car and now it rolls when in park, reverse, drive, 2, 1, when the car is off and on a slight hill. This is the trans that I had in the car before the swap and never had this problem. The only thing I can think of is the trans is a BOP and the lt1 is obviously chevy and I had to use a tranny adapter and maybe it seperated the trans/engine too much and the converter isn't on right. It drives fine and shifts hard but just doesn't sit still when off.
Old Mar 30, 2005 | 11:16 PM
revtime's Avatar
Re: Rolling when in park (car off).
Make sure your shift cable is adjusted properly.
It could feel like it goes all the way into park but is just out enough not to engage the park mechanism.
It may even click as it rolls, I have dealt with this problem on several different cars over the years. It may not be your problem but something to check.
Old Mar 31, 2005 | 02:07 AM
blueta's Avatar
Sorry, I forgot to add that I disconnected the cable and shifted it by hand on the tranny itself and it did the same thing. It also rolled when I did the same thing and left it in gear. I'm a little confused lol!
EDIT: I checked if I put the flexplate on backwards today and it's fine. I forgot that the tranny adapter came with some washers to put between the flexplate and converter and I DID install them so now I'm even more lost.
Old Mar 31, 2005 | 10:39 PM
revtime's Avatar
That is odd.
Now I am thinking its internal.
Might pull the pan and check around in there.
Old Apr 2, 2005 | 08:20 PM
blueta's Avatar
Exclamation Re: Rolling when in park (car off).
Well I went under the car and I tried to put it into park again with my hand. It didn't go any further then it was at...then I put a pipe on the bracket and it went further. It was really tight but should go that far with the cable. The cable isn't adjustable so what the heck can I do? Try to bend the bracket foward a little?
PCLZ28
Dec 24, 2015 05:19 PM
ModdedNerd
Dec 10, 2014 08:42 PM
ro2207
Dec 4, 2014 06:18 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
USAirman93
Nov 24, 2014 03:37 PM
