Will 95 4L60E work in 96?
Old Apr 13, 2005 | 06:31 PM
J96Z's Avatar
I need a new trans and there is a guy local that has one from a 95 Z28 with low miles and I need to know if it will work in my 96. Thanks!
Old Apr 13, 2005 | 06:37 PM
Blown97.SS's Avatar
Re: Will 95 4L60E work in 96?
you shouldn't have a single problem putting a 95 4l60e in a 96
Old Apr 13, 2005 | 06:39 PM
J96Z's Avatar
Thanks a bunch. The 95 trans only has 50k miles on it and he only wants $300 for it. Mine is spraying fluid all over the place from behind the torque converter.
Old Apr 14, 2005 | 06:34 PM
SMOKNZ's Avatar
How 'bout you just replace the input shaft seal?
Old Apr 14, 2005 | 06:37 PM
J96Z's Avatar
I just figured since I have to pull it either way I might as well replace it with a better trans. My roommate said the same thing, that I should just replace the seal. Mine has 136k miles on it and the fluid is black. This trans I am getting has 48k miles on it and is only $300. I will still probably change the seal on it too when I install it.
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Brake_L8
Jan 20, 2015 09:44 AM
Snoman73
Nov 17, 2014 07:22 PM
