how do you unlock 1st gear???
Old Apr 7, 2005 | 10:45 PM
97silvermaro's Avatar
doing a v6 to lt1 swap... i have the z28 tranny but the shifter only goes down to 2nd gear... my shifter goes down to 1st gear in my car... how do i make the z28 tranny be able to go down to 1st? thanks
Old Apr 7, 2005 | 10:58 PM
ROADRAGE's Avatar
Re: how do you unlock 1st gear???
There is just a small piece of rubber that stops the shifter from going all the way back. Pull your console out and look, you cant miss it.
Old Apr 8, 2005 | 04:21 PM
SUTTERERMAN85's Avatar
i just bought a 94 formula and mine only goes down to 2 also? will this work on my car ? thanks
Old Apr 9, 2005 | 09:16 AM
ABA383's Avatar
There is a plastic block molded to the shifter gate that prevents the shifter from going back to first. Pull your console and look at the shifter. the block is on the passenger side. Use a small hacksaw blade and saw off the block and you will be able to engage first manually.
--Alan
Old Apr 9, 2005 | 11:26 AM
wow very simple... thanks for the help guys
Old Apr 11, 2005 | 07:45 AM
1SlowFormula's Avatar
yeah it is very simple I had to do it to mine shortly after getting the car! I used a razor knife it is only a soft material and the whole job takes about 20 minutes, and most of the time was spent taking all my junk out of the console!
It's real easy!
Biggiebound
Apr 20, 2015 07:16 AM
Magenta_Hearts
Mar 30, 2015 09:42 PM
Jul 4, 2005 05:00 PM
simple
Aug 2, 2002 03:30 PM
