Torque Converter Or Not?
Old Mar 24, 2005 | 07:02 PM
Godly96_SS_Here's Avatar
So i have a 96' SS and i am thinking about doing a 2800-3000 stall converter but i've heard that i dont have enough hp yet to run a converter. I'm running loudmouth cat back, SLP air foil, and the ram air intake that came stock on the car. Should i go through with a converter or wait till more power? And if anyone does recomend a converter what application should i use? And how well it worked for you guys?
Old Mar 25, 2005 | 02:19 PM
maroon94z's Avatar
Re: Torque Converter Or Not?
Do you run your car at the track? Sticky tires? If so, a TC will be the best dollar per gain mod you can do. If you just run on the street, you might not be able to take full advantage of a high stall. I lost 4 full tenths with my Edge 3000. That's like picking up 50 HP for $525.
IMO, stall is the single best mod you could do, stock or not. Our motors don't make good power til over 3000 rpm stock, so it would help you no matter what mods you have.
Old Mar 25, 2005 | 04:51 PM
I do run at the track alot and i run street alot being this is my only car, will i need drag radials if i do a tc? or will normal street tires work?
Old Mar 25, 2005 | 06:49 PM
maroon94z's Avatar
I can't say from experience, but I'd have to guess you'd need something more than regular street tires.
Old Mar 26, 2005 | 04:11 PM
94Zpower's Avatar
Maroon is right it is the best mod per dollar that you can do, but as he also said you should definetly get some tires! DR's would be good for the street, you will notice a night and day difference with the new stall,
dont go cheap though get a Protorque, Edge or Vig . you wont be sorry
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
