th350 performance fluid reccomendation
Old Mar 24, 2005 | 11:29 AM
Evil Eric's Avatar
ok guys, i did my tranny swap back over christmas, and this weekend i put a deep pan and aux. cooler in. i havent refilled the system yet, and i was wanting to know should i use regular type F (what the shop said), Dexron III (Autozone's advice) or step up to a synthetic like what i heard from the guy that owns a local hot rod parts place said? i already have enough quarts of b&m trick shift that would do the trick that came from another project that fell through. any opinions? this is a moderate street machine w/ about 360hp at the flywheel with a 2200 stall if that makes a differance.
Old Mar 24, 2005 | 11:53 AM
captaindbol's Avatar
Re: th350 performance fluid reccomendation
Your transmission came with dexron and should have it put back in. Type F has no place in a th350. Synthetic fluid is great but comes at a price (5+ per quart for a quality product). With regular service and a good cooler you shouldn't need synthetic unless your towing in the summer or hot lapping a car with a transbrake. The trick shift is OK if you allready have it but don't expect miracles as it is mostly hype. I recommend the cheapest parts store brand you can find ( AS LONG AS IT IS LABLED MADE IN USA). Exxon-Mobile makes over 80% of the worlds ATF supply which is relabled for many vendors including Advance Auto Parts. You learn all kinds of things when your wife is an engineer for the worlds largest oil company.
Old Mar 24, 2005 | 12:26 PM
Evil Eric's Avatar
cool, Dexron was what most of the people i have talked to have said, but i wanted an opinion from people that actually know and drive the cars.
warmeck
Aug 24, 2024 08:05 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Nostang 96z
Sep 14, 2002 08:22 PM
Nostang 96z
Sep 10, 2002 08:54 PM
