View Full Version : Drivetrain
- '93 tranny with 4.10's?? Bad idea??
- SPEC stage 3 vs SPEC stage 3+, whats the difference?
- Add paddle shifters to your car
- Tremec T56 same as my tranny??
- JW ultrabell
- Looking for parts interchange / historical info on 9-inch rearends
- v6 rear
- I broke the stud on my TA girdle!!! ---
- removing the a4 with lt headers
- New info added to FAO page and we are open for tech/sales for the 4th
- How to remove pinion gear?
- T/O Bearing
- someone please help me with my conversion
- is my stall to big?
- wheel bearings
- auto shifter for 4l60e in s10
- couple questions about this stall
- fastest times on 10 bolt??
- 4L60E Transmission Problems
- Effective drivetrain setup for 93z
- cant get traction
- TH350 Clanking Noise
- third and fourth gear gone after only 3,000 miles
- LT1 Tranny Swap Questions
- Clutch Problems???
- ford 9 inch question
- tranny mount
- Tranny Line Connections...
- Dang A4!
- Mcleod Clutch Problem!
- Clutch reservoir
- Trying to figure gears?
- are 3.08s a good idea?
- breakin period for tc/stall?
- Lots of Ford 9" Rear Questions
- couple TH350 swap questions
- Moser 12 Bolt Rear End Torque Arm Bolt Size
- Difference between LS1 and LT1 T56 and 4L60
- Tranny Help
- pop pop @ stop
- Severe body movement at shift
- Few easy questions..
- TH-400 trans performance build up. Any specs??
- Are my backing plates on right?
- moser 12-bolt wheel studs
- how is the center forcedual friction clutch
- Going through a lot of trans mounts?
- Need help finding a trans bracket!!!
- How do i correct my speedometer!?!?!
- 4L60-E Rebuild?
- Whats the loud bang when I shift?
- The 3.73's are in! Finally
- Can you guess whats misssing?
- Who likes or dislikes their 9in Rear?
- 9" gears and a a4?
- Th350 flexplate
- 3k stall and top end
- Rebalancing or Better Balancing the Stock Steel LT1 Driveshaft
- What KInd of Converter and gears are the best for 96 Camaro SS
- LT1 OBD2 PCM Lockup Points - Stock and Modified
- Transmission swap?
- pre bled master/slave cylinder setup. Where do I buy it fast??
- Help Me Hook UP!!!
- best place to get lt1 clutch master/slave setup at good price..
- A4 & single cat. Torque Converter question?
- Rear End Noise in 4th Gen
- How much weaker are 4.10 gears compared to stock 3.42?
- question about my spec clutch
- 4.10 and a 3200 stall - otherwise stock?
- 4L60e taking too long to shift into second
- 82-92 and 93-02 fitment questions
- Help Choosing Shift Kit
- 373 manual rearend in a 95 camaro auto
- 4L60E differences?
- How much play is normal in a 10 bolt?
- LT1 Stock gears?
- Launching in 2nd gear?
- question about grinding on takeoff in a m6
- t56 shifting problems help please.
- getting gears installed, what grease/lubricates
- abs inop brake light rear end swap
- Must have tips for M6 clutch alignment install
- think i messed my clutch up
- install tc?
- What ATF to use with Yank SS3200
- Frank and CPT
- Tranny Cooler Lines
- A4 Broken
- Why is my speedo off after R&R tranny??
- M-21
- Transgo Shift Kits installation
- Why cant anything go as planned?
- 700r4 No reverse
- rear end rebuild/refresh?
- 4l60e trans gurus please help
- E-Clips...
- What size tap for rear end yolk
- 4l60e symptoms
- Driveshaft length problem.
- Neep help really bad might be trans mount
- Gear Vendors Gear splitter
- First time using Jack Stands ... where to place them?! ---
- Result From Transmission Check...
- Gear Ratio or Speedo?
- Installing lockup converter in 4L60E
- 5 speed help needed
- hard to get into any gear, then...
- gm part numbers
- csc conversion
- t56 rebuild question (tailhousing)
- converter advice
- Lock up vs non lockup
- Clutch disengage problem
- rebuilding T56 have a couple questions, pics included, 56k I dunno
- How to tell Auburn or Torsen diff
- t-56 Master Upgrade What Fits?? Just mcleod???
- CPT ProRace + ProYank 3600 =
- that'll do pig, that'll do
- stock shift points
- Mcleod Adjustable master. Alternative?? Better price??
- 4L60E to TH350
- McCleod Twin disc question
- Car takes off in 2nd after drag strip burnout
- hot clutch or burned up?
- What gears would be the best for a street car?
- help! very bad news....
- plastic slave cylinder and headers
- what type of posi isin a 2002 TA ?
- TV cable adjustment
- Went from a 93 to 95 6speed
- cross pin on auburn possi
- Trans ?????
- Torque converter
- Clutch Master Cylinder question-LT1 guys
- ring gear install,now noise when turning right
- Bad to Let Off Before Gear Change in an Auto?
- 2001 Camaro SS Clutch problem
- Help!!
- Mcleod Clutch Questions
- Installing a 3 channel 3.42 rearend in place of factory 4 channel 2.73 rear A4 Z28
- Why does the T56 sound like it has loose marbles in it?
- best clutch?..
- make stock clutch master cylinder to adjustable
- clutch problems
- When does the converter in my '93 lock up?
- 4l60e not shifting
- Testify! 3.73 Gears
- Weird Vibration
- Need help on TV cable
- Who has used an Auto Weld Chassis 9"?
- Another Happy CPT Customer
- Daily driven stalled guys...
- Re: Problem with Centerforce Clutch! HELP??
- Rebuilding my 4L60
- Weird issue concerning 3rd gear
- Gear and shifter ?
- Ram Aluminium Flywheel Pics LT1
- thm400
- moser 9 inch axle seal part number?
- LS7 Clutch Issues
- No 1st Gear After Transgo Shift Kit
- Bad Vibration
- Trans was just rebuilt, and now a few problems
- lets talk about Shift Knbos
- Best way to bleed and lt1 hyd clutch?
- 4l60e not downshifting
- what would it take??
- Is this the clutch I need?
- Weridest bleeding problem and random solution
- can i keep the 93 tranny when switching to a 94 pcm?
- going from 4L60E to 700R4
- Good T56 Overhaul Kit??
- Slave cyl. woes!
- Converter fluid
- Master cylinder reinstall problems
- pressure plate bolts
- converter
- Is it bad for your tranny if you clutch it at 6k rpm?! ---
- Grinding noise from the rear - 99 SS
- 12 bolts lube: 75w90 or 80w90
- Looking for a dimensional drawing of a 10 bolt rear end
- Will this converter work well on my car?
- Hey, guys with supercharger/turbo charged M6's please help out!!
- LT1 M6 without pilot bearing?
- Torque Converter Question
- Noise coming from rear when turning
- No pedal pressure after clutch install
- Grinding Gears
- Front end area thumping noise
- shifting problem
- Rear end ratio
- Moser 12 bolt fluid and abs question
- torque arm instalation
- clicking noise coming from drivetrain
- M6/T56 Synthetic or Non-Synthetic ATF
- Car vibrates bad after tranny mount install
- GM additive in tranny
- How hard is it to change A T-56 Clutch?
- rear end for street twin?
- T-56 first gear Q's??
- 3.73's
- Broken Slave Cylinder Line! Need some help bad!
- Testing the reverse lockout solenoid??
- Ford 9"/True-Trac help
- Any idea what this could be?
- HELP!!! Any ideas-wont start in Park
- Help trans issues staying in 4th
- No 1st gear and manual shift only
- no 2nd or 4th gear in fresh 700r4
- 4l60e to th350 Conversion
- Need flywheel help!
- couple of stall questions
- Busted driveshaft?
- turbo 375?
- torque arm bolts
- Walthrough for changing LT1 hydraulics?
- torque arm insulator
- 6 speed differance
- transmission mount
- Clutch choices.. help me choose
- dyno w/ a4
- Clunk and No 6th
- Q about checking trans fluid
- Post your clutch setup and how you like it.
- LS1 Tranny Lines
- Posi going out???
- Need tech help on clutch/trans
- Groaning/Squeeking when slowly turning
- No Forward Gears
- 2.73s to 3.73s....Yes, MPG Goes Down
- 1st and 2nd vibrating erratically(T56)
- Changing fluid in Strange 12 bolt??.....
- I can't shift into third while racing (T56) v.ouch
- A4 temp question
- 4L60E shift cable replacement
- Is the vigilante worth the dough!
- 90+ MPH vibrations
- Clutch disc install...Wich side???
- Stripped bolt in Aux Valve body, HELP!
- 9" Differential Question?
- Time For New Rear End!!!
- Newb Transmission Question
- Bench Bleed new Slave?
- Mcleod single or Spec stage 3+ ????
- Is this stall going to be okay for me?
- sachs super set or Ram HDX
- Can you reuse SPEC stage 3 clutch disk?
- Another satisfied customer
- Strange transmission problem
- 3.23 - 3.73 :: The difference
