are 3.08s a good idea?
Old Jun 30, 2007 | 02:43 PM
camz28aro's Avatar
Question are 3.08s a good idea?
I want to do 3.08s on my camaro a4 with street tires, I don't want to go bigger than that so I can still getgood gas milage and I think 12% higher ratio is good enough. My questions are, Is a richmond 3.08 less prone to breaking than a stock 2.73?, Do you think I have a good chane of breaking it with a soon to be 330-340rwhp car? and what are some guesses in my ET drop?(0.1/0.2?) I won't run stickys cause im too scared to break it. Thanks.
Old Jun 30, 2007 | 02:49 PM
mdacton's Avatar
would not change a thing...
Old Jun 30, 2007 | 03:52 PM
bombebomb's Avatar
Thats such a small change, you would barely notice any change, if you could notice it.
Old Jun 30, 2007 | 04:47 PM
2000GTP's Avatar
Even if you stepped up to 3.42s or 3.73s, your gas mileage shouldn't suffer too much. I would opt for one of those two instead of spending the time and effort going for the 3.08s.
Old Jun 30, 2007 | 05:24 PM
karpetcm5's Avatar
^^^ Id have to agree i had a 95 Z A4 went to 3:42's felt a difference but wish i went to 3:73's. If your that worried about gas mileage do 3:23's some factory camaro's came with those and there pretty quick when i eventually got my 01SS 6speed they would actually easily keep up and in some cases beat me. But if your gonna open it up go with better gears then 3:08's if not just keep what you got. I do understand what your saying, from my own experience when i went from 2:73's to 3:42.s in my 95 A4 the cruise speed on the highway was about 400 rpms higher, gas mileage did suffer a bit but the end result was a car that got off the line much better stayed in its power range longer and got there quicker. As far as breaking it, its always possible with our rear ends now in my 1993 6speed im running 392 rwhp 434 rwtq with 4:10's. Ive had 3 camaro's did rear changes in all definitly worth it if you select the right gears, as far as how much it will shave off the E.T thats always gonna be a guess but if you go from 2:73's to 3:42's its about .3 - .4 tenths thats how mine was on my 95 A4 street tires not slicks. Go with better gearing and ofcourse even better. I did it for the main reason stated above but last but not least its hella fun with better gearing.
http://www.cardomain.com/ride/523091
DirtyDaveW
Dec 1, 2016 05:37 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Dec 23, 2014 07:52 AM
Manaz101
Aug 26, 2002 04:26 PM
