Trans ?????
Old Jun 16, 2007 | 12:03 AM
lefty's Avatar
Trans ?????
My trans has park,reverse,1st and 2nd.Its not shifting into 3rd and not sure yet about 4th.Any ideas on what could be wrong?
Old Jun 16, 2007 | 12:07 AM
Performabuilt's Avatar
Supporting Vendor
Does it neutral on the 2-3 shift or just stay in second
Old Jun 16, 2007 | 12:19 AM
lefty's Avatar
if i let off the gas the rpms drop.It does not stay in the gear like putting it in 1
Old Jun 16, 2007 | 09:02 AM
Supporting Vendor
What I mean is if you take off normally during the shifts does it feel like a normal 1-2 but when its time for 3rd does it feel like you shifted to neutral? If so you likley have a 3-4 cluthc failure.
Old Jun 16, 2007 | 09:51 AM
12SCNDZ's Avatar
If you have a 1-2-neutral shift, it's most likely your 3-4 clutches. Feel free to give me a call if you'd like to discuss it further. 302-250-1202
Thanks,
Frank
CPT
Old Jun 16, 2007 | 11:19 AM
lefty's Avatar
No it stays in second gear
Old Jun 16, 2007 | 12:06 PM
Supporting Vendor
You could have a stuck solenoid A (1-2) it and soenoid B(2-3) must go off in order to have 3rd.
1st=both on
2nd=A-off B-on
3rd=BOTH OFF
4th=A-on B-off
But generally speaking if the 2-3 shift is being comanded you should set a code. Have you had the car scanned? Or looked at the data stream to see what the PCM is comanding gear wise?
Last edited by Performabuilt; Jun 16, 2007 at 06:27 PM. Reason: switched solenoid values
Old Jun 16, 2007 | 03:09 PM
12SCNDZ's Avatar
1st=both on
2nd=A-ON B-OFF
3rd=BOTH OFF
4th=A-off B-ON
UM..
The CORRECT 4L60E solenoid firing order is:
1st gear: "A" ON "B" ON
2nd gear: "A" OFF "B" ON
3rd gear: "A" OFF "B" OFF
4th gear: "A" ON "B" OFF
Frank
CPT
Old Jun 16, 2007 | 03:13 PM
12SCNDZ's Avatar
Get the car scanned. This could also be a bad 3-2 downshift solenoid, or sticking valve. The "B" solenoid may also be haniging "ON".
Frank
CPT
Old Jun 16, 2007 | 03:37 PM
lefty's Avatar
I rented a acetron? super scanner.Its the orange one.I couldnt fint any trans codes.do I have to scan it while Im driving or is that the wrong kind of scanner? If so what kind of scanner is the right one and who would have one?
Old Jun 16, 2007 | 03:43 PM
12SCNDZ's Avatar
If the solenoid is mechanically locked in the "ON" position, it may not throw a code. I use a Snap-On MT2500 for diagostic purposes. It allows me to watch all the commands and see when/if the computer is commanding the shifts. Of course, not everyone has access to one of these scanners, because they are rather expensive.
Frank
CPT
Old Jun 16, 2007 | 06:25 PM
Supporting Vendor
Originally Posted by 12SCNDZ
UM..
Frank
CPT
I stand corrected. I mistakingly switched the 2nd and 4th solenoid layouts. That is a nice scanner I have one also. Much better than the little handheld tuners you see so many of. The only thing I have seen I liked better to veiw data is LS1EDIT.
Old Jun 16, 2007 | 09:10 PM
lefty's Avatar
Should i just swap the solenoid and see if that fixes it?I take it only good transmission shops would have the Snap On M2500?
Old Jun 16, 2007 | 09:58 PM
Supporting Vendor
Actually any more reputable shop would have it or the OTC version,But considering the solenoids are like 20 a peice at the dealer I would just buy both shift solenoids and change them and see what happens. Wouldnt hurt to see whats in the pan anyway .
Old Jun 17, 2007 | 08:45 AM
12SCNDZ's Avatar
Shift solenoids are pretty inexpensive and they're easy to change. Just figure on doing a service while you're there. Grab yourself some new fluid, a pan gasket, and a filter. Try to find a Durapreme, or Farpak pan gasket, if you can. They are much better than cork or rubber. Many times, you can only find them at a transmission shop. If you have any questions about changing the solenoids, feel free to give me a call. 302-250-1202.
BTW, I can drop ship you both solenoids, the pan gasket, and the filter for $50 (including shipping).
Thanks,
Frank
CPT
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 23, 2015 12:59 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
