transmission mount
transmission mount
I broke mine yesterday so ordering a new one today, when I go through summit it does not have 93-97 as an option just 98-02, I know 98-02 has same transmission, but will the mounts stil work on my 94?
http://store.summitracing.com/egnsea...=KeywordSearch These are the ones listed for a 98
ok I got it today, I dont see anything that screams preload plate though. All I got is this
mount
2 7/16"-14X1 1/2" Stud
2 7/16"-14 NUT
2 7/16" Lock Washer
2 7/16" Flat Washer
So is the preload plate even here?
mount
2 7/16"-14 NUT
2 7/16" Lock Washer
2 7/16" Flat Washer
Yup, shoulda bought a factory LS1 mount
. I couldn't take the vibes that the ES poly mount transmitted through the car, so I'm still on my stock mount, with ~60k on it, drag raced lots and road raced quite a few times as well
. It's significantly better than the factory LT1 mount, but it's softer than the poly mount, so it doesn't rattle your fillings out
I just installed mine today. It does vibrate alittle, but mine isnt a daily driver, so i dont really care. I didnt really see that the plate was a seperate piece. I thought it was molded into the poly. I didnt think to take it off.
Another point worth mentioning is that I have a steel driveshaft (as many others do) and they are more prone/famous for vibrating, compared to the aluminum ones which are lighter, and seem to have less balance issues.
And for me, it didn't matter whether I had that extra plate in with the ES mount or not ... it was equally as bad either way
