JW ultrabell
Old Jul 4, 2007 | 10:07 PM
mdacton's Avatar
JW ultrabell
anyone running one?
I would rather go that route than trying to use a shield......the tunnel is tight as it is
http://www.jegs.com/webapp/wcs/store...10002_37436_-1
Old Jul 5, 2007 | 01:49 AM
revtime's Avatar
I run an ultrabell on my Rossler TH400.
It fit fine in my 94 except for the 2nd bolt up on the drivers side. It takes a little massaging or if you can do it pulling the trans/motor combo towards the passenger side to get the itsy bit of clearance you need to get the bolt in or out.
Keep in mind the ultrabell will save your floorboard and tootsies if the converter and/or flexplate come apart but you will still need a trans shield or blanket to be NHRA legal. The ultrabell won't help if the planetaries decide to exit stage left.
Old Jul 5, 2007 | 06:44 AM
mdacton's Avatar
^^ thats the same bolt i'm having problems with.........
the trans cover won't be a problem, I just didn't want to go with the sheild for the flex plate, I was pretty sure it would not fit
Collector Car
Aug 15, 2013 10:38 AM
Collector Car
Jan 28, 2013 02:49 PM
nitrious junkie
Jan 22, 2012 09:59 AM
mario89
Jun 13, 2009 07:54 PM
Mean Green
Aug 30, 2008 11:02 AM
