Tranny Help
Old Jun 29, 2007 | 09:56 PM
Don350k's Avatar
Tranny Help
Ok guys im @ a loss here, this is my wifes vehicle, i know its not an fbody but i thought a few of you might have some ideas, The Car is a 99' Mitsu Eclipse Auto 2.8(think its a 2.8 non turbo 4 banger)
The tranny will go in a loop mode sometimes and stick in second, and then drive fine sometimes, but it will have neutral and reverse when it does.
I am thinking it is a electrical problem, all grounds check and connections, will the VSS going out cause this? BCM failing?
The OBDII is throwing these codes
PO733
Gear 3 Ratio Incorrect
PO731
Gear 1 Ratio Incorrect
PO715
Imput/Turbine Speed Sensor A Circut Malfunction
P1782
Manufacturer Contrl Transmission
P0700 Trans Control Sys Malfunction
DTC Pending Codes
P0700 Trans Controll Malfunction
I do notice i am not throwing a code for second gear and this is the gear it sticks in! lol
Thx Don
Old Jun 29, 2007 | 10:55 PM
Performabuilt's Avatar
Supporting Vendor
2ND gear is limp mode in these cars and they are known to kill a TCM but with so many codes I would check my wiring and all the trans conectors fuses and grounds. If all are good I would replace the in put and out put speed sensors fist as they to go bad on these quite often Then as a last resort I would replace the TCM. I have spent many hours messing with these in the past. Not bad little trannys but can be electronics nightmares.
PO733
PO731
PO715
P1782
DTC Pending Codes
Thx Don
Old Jun 30, 2007 | 06:24 PM
Don350k's Avatar
Thx, im picking up a haynes manual to figureout what senor is what and going from there, thx for your time and advice, i will use it!
Thx
Don
Old Jun 30, 2007 | 08:40 PM
Supporting Vendor
I am rying to figure out which of two possible transmisions you have but the problem i am getting is they ae only showing two engine options in 99 2.0 and 2.4 ?
And actually looking over your codes again I would start replacing the input speed sensor first. its the one nearest the bell with two wires to it reguardless of unit type
Old Jun 30, 2007 | 11:00 PM
Don350k's Avatar
i dont remember the engine sise off the top of my head, but that sensor is spliced in as it is with wire conectors......
i was wondering abought that myself
Don
Old Jun 30, 2007 | 11:07 PM
mdacton's Avatar
I used to work at a dealer...the input sensors would go all the time. I think its the same motor/trans as a neon and some other chrystler cars (breeze?) If you have anyway of scannig it.......search around for service bulletins too. Sometimes they need a computer reflashed
Old Jun 30, 2007 | 11:32 PM
Supporting Vendor
FIX THE WIRING FIRST THEN , i HAVE WORKED ON THESE FOR YEARS GOOD TRANS ACTUALLY JUST VERY PARTICULAR ABOUT ELECTRONICS
Don
Old Jul 1, 2007 | 04:58 PM
Don350k's Avatar
sounds good, ill get back to ya on it
Don
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
