4l60e symptoms
Old Jun 20, 2007 | 09:27 PM
mercedestech's Avatar
Question 4l60e symptoms
I have a 1994 z28 with a 4l60e. The only aftermarket parts are a magnaflow cat back, moroso cold air intake, and msd billet optispark unit. My trans has a few very annoying problems i hope one of the tranny guys can help me with. First, there is no engine braking on decel unless it is in overdrive (I assume this is because the convertor is locked up in overdrive which provides the engine braking effect). Is there a common problem with any particular seal or hardpart on the over run clutch pack? Also I get a slight flare shift on my 1 to 2 upshift...nothing terrible, but not nearly as "tight" as it should be. The last I only noticed after installing the magnaflow exhaust..???... On wide open throttle, the engine will actually bounce off of the rev limiter 2-3 times before shifting if i don't back off the throttle slightly. The first two issues have been present for the last 15K miles, so I don't beleive it is anything catastrophic. I am willing to do a rebuild myself ( I work on Merceds Benz vehicles for a living) if that's all it needs. Any input you tranny experts have would be great....if your recommending a rebuild, whose rebuild kits or parts do you recommend. Thanks in advance for any help you might offer.
Old Jun 20, 2007 | 10:28 PM
'94 Bad A Z28's Avatar
I'm not a trans guy but that trans is on it's way out.
Old Jun 20, 2007 | 11:25 PM
ttop1986's Avatar
Mine did exactly what yours is doing. The fix... send it to frank @ CPT and he will turn it into a beast.
Old Jun 20, 2007 | 11:48 PM
Performabuilt's Avatar
Supporting Vendor
It does sound like its on it way out check out our website thanks
Old Jun 21, 2007 | 06:22 AM
12SCNDZ's Avatar
This sounds like you're beginning to see internal problems. One of them is definitely in your over-run clutch area.
Frank
CPT
Old Jun 21, 2007 | 06:27 AM
12SCNDZ's Avatar
Thanks for the support. It's nice to have such a positive customer following. It took us a while to earn the great reputation we have. We treat all of our customers as our friends, and we also give them the best products available.
We've been continually rated the best on our transmission reputation, our prices, and our customer service.
Frank
CPT
Parts Wanted
May 1, 2016 10:25 AM
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
tdigger9899
Sep 7, 2015 10:56 AM
