GM additive in tranny
Old May 31, 2007 | 10:17 PM
deputydough's Avatar
has anyone ever heard of putting the GM gear additive(rear end) in the transmission to stop the shuddering you get sometimes?? i had a guy from the chevy parts counter tell me it would stop the shuddering.
Old May 31, 2007 | 10:21 PM
n2ceptor's Avatar
Probably be OK, if your manual trans takes gear oil and not DEXRON....
Old Jun 1, 2007 | 07:13 AM
always faster's Avatar
What grade 75w90/80w90?
Old Jun 1, 2007 | 07:30 AM
I thought shuddering came from the clutch. I can't see a transmission causing it.
Old Jun 1, 2007 | 07:32 AM
What n2ceptor was trying to say is the T56 does not use gear oil.
Old Jun 1, 2007 | 08:32 AM
Maybe im missreading but he says to use gear oil and not put Dexron(wich is automatic fluid) in it
Old Jun 1, 2007 | 09:44 AM
wayfastwhitey's Avatar
Go back and read it again. He says that it would be ok, if his trans takes gear oil rather than trans fluid. He then ends the sentence with a smiley face.
He was being sarcastic.
Old Jun 1, 2007 | 10:23 AM
00ls100's Avatar
I've never heard of anyone putting gear additive in the tranny. I think the guy at the chevy dealership was telling you some BS. I just recenty changed my tranny fluid actually and it went from having notchy shifts and sometimes grinding to smooth. -It might just all be in my head though lol.
Old Jun 1, 2007 | 03:06 PM
n2ceptor's Avatar
I am not being sarcastic, Depending on the type of manual transmission will dictate the style of fluid.... As far as the smilely face, I always use one on the end of my statements...
I thought my previous statement was clear and direct.. I guess not???
Old Jun 1, 2007 | 06:04 PM
Wild1's Avatar
The 95 will take Dextron III.
By the way, since you mentioned the additive pack, I just picked some up for the differential fluid change this weekend. $14.95 plus tax
Old Jun 1, 2007 | 06:09 PM
mdacton's Avatar
Wild1 I pay $4.94 for it......
Try a going to a synthetic fluid....sometimes it helps in cooler temps.
Don't put the additive in it....its a friction modifier, it won't do anything
Old Jun 1, 2007 | 09:16 PM
ok guys, i realize i have a t56 which takes dexron3. but, i have a truck that has an auto and that is what i was referring to. sorry, i should have been more specific. i just thought it might apply to anyone with an auto. just thought it was interesting. this guy is pretty sharp and has never steered me wrong before.
Old Jun 1, 2007 | 09:28 PM
n2ceptor's Avatar
I know you could try this.. Its safe for DEXRON... PArt # AT-202..
Old Jun 1, 2007 | 10:10 PM
Wild1's Avatar
Since you're dealing with Dextron III, additives shouldn't be a problem. I've never documented rear-end additive for the A/T but have used a BG additive called Shudder Guard with some success.
I wouldn't recommend Shudder Guard on SP-III ATF, only Dextron and Mercon. Even though the label says it is safe with all A/T fluids, it isn't.
So, with Dextron III, an additive would be relatively safe. Again, I've never used anything but A/T additive for the A/T.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
